Ohmic Enable Check Box
  • snowgoer540
  • snowgoer540's Avatar Topic Author
  • Moderator
  • Moderator
22 Jul 2020 16:34 #175421 by snowgoer540
Ohmic Enable Check Box was created by snowgoer540
I might have found a bug... The ohmic check box doesnt seem to be fully listening. When I uncheck it, the power supply for Ohmic still turns on for Ohmic Test, Probe Test, and when I run a program. Further, the GUI still shows when an Ohmic touch is detected. Plasmac seems to ignore the ohmic touch (because the float switch does trip each time).
Perhaps it's working as intended, but I would have expect disabled to be disabled, meaning I would have expected it to not power on the associated pin (and power supply), and not show any trips in the GUI.
22 Jul 2020 19:57 #175430 by phillc54
Replied by phillc54 on topic Ohmic Enable Check Box
It is working the way I intended which is if disabled PlasmaC ignores the ohmic input as a probing input.
Should it be different... I don't know, I don't use ohmic at this stage.
We'll see what others think.
  • snowgoer540
  • Moderator
  • Moderator
22 Jul 2020 20:31 #175438 by snowgoer540
Replied by snowgoer540 on topic Ohmic Enable Check Box
Good to know it’s working as intended. I guess maybe it’s semantics, ignore ohmic vs disable ohmic. Was just thinking if you didn’t want ohmic for whatever reason, you probably don’t want the output for it enabled either. Plus I was a bit confused seeing the ohmic still trigger each time ¯\_(ツ)_/¯
22 Jul 2020 20:34 #175440 by phillc54
I can see wher you are coming from...
23 Jul 2020 03:48 #175477 by rodw
Replied by rodw on topic Ohmic Enable Check Box
¯\_(ツ)_/¯
Sorry I have no idea what you are talking about! :side:
  • snowgoer540
  • Moderator
  • Moderator
23 Jul 2020 04:01 #175481 by snowgoer540
¯\_(ツ)_/¯
haha, sorry, maybe those aren't allowed here, my phone is set to change "shrug" into that ASCII art, and it's sort of force of habit now.
23 Jul 2020 04:53 #175490 by rodw
¯\_(ツ)_/¯
NAh its OK just Google Translate drew a blank!
23 Jul 2020 04:57 #175492 by Clive S
Replied by Clive S on topic Ohmic Enable Check Box
¯\_(ツ)_/¯
Don't forget Rod that you are upside down :laugh:
23 Jul 2020 05:12 - 23 Jul 2020 05:13 #175496 by rodw
Yeh, I tried compensating for it by turning my chromebook upside down bu the darn thing rotated the screen!
Last edit: 23 Jul 2020 05:13 by rodw.
  • snowgoer540
  • Moderator
  • Moderator
23 Jul 2020 05:13 #175497 by snowgoer540
My ability to break things knows no bounds. ¯\_(ツ)_/¯
Time to create page: 0.358 seconds
