Ohmic Enable Check Box
- snowgoer540
- Thank you received: 906
22 Jul 2020 21:34 #175421
by snowgoer540
Ohmic Enable Check Box was created by snowgoer540
I might have found a bug... The ohmic check box doesnt seem to be fully listening. When I uncheck it, the power supply for Ohmic still turns on for Ohmic Test, Probe Test, and when I run a program. Further, the GUI still shows when an Ohmic touch is detected. Plasmac seems to ignore the ohmic touch (because the float switch does trip each time).
Perhaps it's working as intended, but I would have expect disabled to be disabled, meaning I would have expected it to not power on the associated pin (and power supply), and not show any trips in the GUI.
- phillc54
- Thank you received: 2100
23 Jul 2020 00:57 #175430
by phillc54
Replied by phillc54 on topic Ohmic Enable Check Box
It is working the way I intended which is if disabled PlasmaC ignores the ohmic input as a probing input.
Should it be different... I don't know, I don't use ohmic at this stage.
We'll see what others think.
- snowgoer540
23 Jul 2020 01:31 #175438
by snowgoer540
Good to know it’s working as intended. I guess maybe it’s semantics, ignore ohmic vs disable ohmic. Was just thinking if you didn’t want ohmic for whatever reason, you probably don’t want the output for it enabled either. Plus I was a bit confused seeing the ohmic still trigger each time ¯\_(ツ)_/¯
Replied by snowgoer540 on topic Ohmic Enable Check Box
- phillc54
23 Jul 2020 01:34 #175440
by phillc54
I can see wher you are coming from...Good to know it’s working as intended. I guess maybe it’s semantics, ignore ohmic vs disable ohmic. Was just thinking if you didn’t want ohmic for whatever reason, you probably don’t want the output for it enabled either. Plus I was a bit confused seeing the ohmic still trigger each time
- Thank you received: 4149
23 Jul 2020 08:48 #175477
Replied by rodw on topic Ohmic Enable Check Box
- snowgoer540
23 Jul 2020 09:01 #175481
by snowgoer540
haha, sorry, maybe those aren't allowed here, my phone is set to change "shrug" into that ASCII art, and it's sort of force of habit now.
¯\_(ツ)_/¯
Sorry I have no idea what you are talking about!
23 Jul 2020 09:53 #175490
NAh its OK just Google Translate drew a blank!
¯\_(ツ)_/¯
- Clive S
- Thank you received: 486
23 Jul 2020 09:57 #175492
by Clive S
Don't forget Rod that you are upside down
Replied by Clive S on topic Ohmic Enable Check Box
¯\_(ツ)_/¯
23 Jul 2020 10:12 - 23 Jul 2020 10:13 #175496
Yeh, I tried compensating for it by turning my chromebook upside down bu the darn thing rotated the screen!
Last edit: 23 Jul 2020 10:13 by rodw.
- snowgoer540
23 Jul 2020 10:13 #175497
by snowgoer540
My ability to break things knows no bounds. ¯\_(ツ)_/¯
Time to create page: 0.478 seconds
