- Thank you received: 907
Feature Request
- snowgoer540
- Topic Author
At least three reasons I can think of:
1. Cutting expanded metal in CPA mode
2. End of cut lead outs. Where you want the torch to continue to travel for the flame to catch up, and the piece of material might drop out and cause a flame-out (this happens most to me with holes, even though I use no lead-out).
3. Thin materials. I spend the most time "testing" (:laugh:) the paused motion features when I cut thin materials. Even though I don't have a lead-out, the torch usually has around 0.030" or so of travel to go, but it loses the arc, so it pauses. Which is really annoying when you're trying to let it run unattended.
In my mind it would work exactly like THC where you can:
1. turn it on and off permanently from the GUI
2. turn it on and off with the particular material recipe
3. turn it on and off with G-code
The last option would allow you to ignore the arc-OK signal say .1" from the end of the cut with a SheetCAM rule, etc.
One last thing regarding cutting expanded metal, while doing some research for this (to see how other vendors handle it), I read here where Jim Colt recommended not using CPA mode when cutting regular metals:
Make sure for normal cutting that your plasma is in the cutting mode. Normal cutting with the switch in the expanded metal position will cause shorter nozzle life, and may also affect cut quality.
Jim Colt Hypertherm
It could be made automatic for machines with RS485 when CPA mode is selected.I think we need a way to ignore Arc-OK signals
Don't you stop the travel to wait for the catchup, like Arc Dwell here:End of cut lead outs. Where you want the torch to continue to travel for the flame to catch up
linuxcnc.org/docs/2.8/html/plasma/plasma...#_hole_cutting_intro
I mainly cut 1.6mm (16 Gauge (what a wierd measurement)) and haven't seen the issue you noted.Thin materials
I don't have a choice, that is how my machine (Powermax 30XP) is...Make sure for normal cutting that your plasma is in the cutting mode. Normal cutting with the switch in the expanded metal position will cause shorter nozzle life, and may also affect cut quality.
Jim Colt Hypertherm
- snowgoer540
- Topic Author
I’m not sure I follow? I know it can select CPA mode for you, but the problem is you’ll lose the arc-ok signal after the first piece of expanded metal, and it’ll stop.
Even with the dwell feature, if it flames out while waiting for the dwell to complete, it’ll pause. Whereas if you had the option to force the arc-ok to true for that portion of the cut no matter what the plasma power source actually did, it would continue on its merry way.
What I meant was that I could make it so when it was in CPA mode it would automagically ignore a loss of Arc OKI’m not sure I follow? I know it can select CPA mode for you, but the problem is you’ll lose the arc-ok signal after the first piece of expanded metal, and it’ll stop
I understand what you mean. It is just that I have not seen this issue and I am surprised no-one else has mentioned it.Even with the dwell feature, if it flames out while waiting for the dwell to complete, it’ll pause. Whereas if you had the option to force the arc-ok to true for that portion of the cut no matter what the plasma power source actually did, it would continue on its merry way.
- snowgoer540
- Topic Author
phillc54 wrote: What I meant was that I could make it so when it was in CPA mode it would automagically ignore a loss of Arc OK
Ah ok! That’s a good thought for ignoring it altogether. Of course in its singularity it only benefits the hypertherm folks I guess.
Sorry just was making sure we were on the same page. Honestly I’m offended you’re even questioning my ability to break things :laugh:
I would never question that!snowgoer540 wrote: Sorry just was making sure we were on the same page. Honestly I’m offended you’re even questioning my ability to break things :laugh:
What size sheet are you seeing this on?
