Feature Request
23 Jul 2020 14:42 #175550 by Clive S
Replied by Clive S on topic Feature Request
This is some code that I used on a Warco Mill in 2016 that "CNCBASHER" helped me with very similar to Rods.
#custom mpg handwheels for 7i76  + pause/resume
# lcnc v2.7
# x axis fixed to enc0
# enc1 switched to y or z
# load real time components
	loadrt mux_generic config="ff256"
	addf mux-gen.00 servo-thread
# Send the jog counts to each axis, only the one selected will move
# x encoder
 net mpg-count-x	<=  hm2_5i25.0.7i76.0.0.enc0.count
# y or z encoder
net mpg-count-y	<=  hm2_5i25.0.7i76.0.0.enc1.count
#for velocity mode set to 1
#set for position mode 0 ( default)
setp axis.0.jog-vel-mode 0
setp axis.1.jog-vel-mode 0
setp axis.2.jog-vel-mode 0
#	X axis
	net mpg-count-x => axis.0.jog-counts
#	Y axis
	net mpg-count-y => axis.1.jog-counts
#	Z axis( use y encoder here to )
	net mpg-count-y => axis.2.jog-counts
setp mux-gen.00.debounce-us 200000
setp mux-gen.00.suppress-no-input False
	# Set up the scale factors for the scale selector switch
	#1
	# 0.01 mm per click of the MPG
	setp mux-gen.00.in-float-01 0.01 #( default)
	#2
	# 1.0 mm per click of the MPG
	setp mux-gen.00.in-float-02 1.00
	#3
	# 0.5 mm per click of the MPG
	setp mux-gen.00.in-float-04 0.5
	#4
	# 0.1 mm per click of the MPG
	setp mux-gen.00.in-float-08 0.1
	#5
	# 0.05 mm per click of the MPG
	setp mux-gen.00.in-float-16 0.05
	#6
	setp mux-gen.00.in-float-32 0.01
	#7
	setp mux-gen.00.in-float-64 0.01
	#8
	#setp mux-gen.00.in-float-128 0.01 #???
#	X axis enable
	#x axis is always enabled as it has it's own mpg
	setp axis.0.jog-enable true
# now create an external switched input to select y or z enable
#	Y or Z axis enable
	net   mpg-y axis.1.jog-enable  <= hm2_5i25.0.7i76.0.0.input-06
#	Z axis
	net mpg-z axis.2.jog-enable <= hm2_5i25.0.7i76.0.0.input-07
	# MPG Scale
	# set the MPG scale based on the input from the selector switch
	#1
	net pos1 mux-gen.00.sel-bit-00 <= hm2_5i25.0.7i76.0.0.input-09
	#2
    	net pos2 mux-gen.00.sel-bit-01 <= hm2_5i25.0.7i76.0.0.input-10
    	#3
    	net pos3 mux-gen.00.sel-bit-02 <= hm2_5i25.0.7i76.0.0.input-11
    	#4
	net pos4 mux-gen.00.sel-bit-03 <= hm2_5i25.0.7i76.0.0.input-12
	#5
	net pos5 mux-gen.00.sel-bit-04 <= hm2_5i25.0.7i76.0.0.input-13
	#6
	net pos6 mux-gen.00.sel-bit-05 <= hm2_5i25.0.7i76.0.0.input-14
    	#7
    	net pos7 mux-gen.00.sel-bit-06 <= hm2_5i25.0.7i76.0.0.input-15
    	#8
	net pos8 mux-gen.00.sel-bit-07 <= hm2_5i25.0.7i76.0.0.input-16
net mpg-scale-out <= mux-gen.00.out-float
# Set the jog scale output to all axis
net mpg-scale-out axis.0.jog-scale axis.1.jog-scale axis.2.jog-scale
#  Autohome + cycle start (unused )
# remember comment out cycle start in Hal
# uses cycle start switch as home all ..
# if homed then switch becomes cycle start
# loadrt logic names=home-logic personality=0x502
# addf home-logic servo-thread
# note do not invert cycle-start button here or..
# on pressing, homing will cycle around and not stop.
# Set cyclestart gpio pin here & uncomment the next line
#net cycle-start hm2_5i25.0.7i76.0.0.input-00 => home-logic.in-00
#setp debounce.0.delay 30
#net home-state-raw halui.joint.0.is-homed  => debounce.0.0.in
#net home-state-cleaned debounce.0.0.out home-logic.in-01
#net home-state halui.joint.0.is-homed  => home-logic.in-01
#net home-cmd home-logic.xor  => halui.home-all
#net run-cmd  home-logic.and  => halui.program.run
########### END AUTO HOME #################################
########## Run/Pause & Hold/Resume ######################
loadrt and2 count=4
loadrt or2 count=1
loadrt toggle count=1
loadrt toggle2nist count=1
addf and2.0 servo-thread
addf and2.1 servo-thread
addf and2.2 servo-thread
addf and2.3 servo-thread
addf or2.0 servo-thread
addf toggle.0 servo-thread
addf toggle2nist.0 servo-thread
### Panel Leds ###########################
# panel led's
# to show when paused & Step is selected
net pause-on hm2_5i25.0.7i76.0.0.output-00
net step-sig hm2_5i25.0.7i76.0.0.output-01
#increment led
# link pos1 of mux to output 2 & invert
net pos1 	 hm2_5i25.0.7i76.0.0.output-02
setp hm2_5i25.0.7i76.0.0.output-02-invert true
# notes:
# uncomment the next lines for testing Leds work
# connect led's between gpio pin and ground
# make sure they are 12v Leds' as they are on Field power.
#setp hm2_5i25.0.7i76.0.0.output-00-invert true
#setp hm2_5i25.0.7i76.0.0.output-01-invert true
##### end Panel leds ##########################
# run / pause
# Notes:
# Functionality
# Pressing (CycleStart) Run/Step will begin executing a program.
# Pressing Hold/Resume while a program is running will pause the program.
# Pressing (CycleStart) Run/Step while a program is paused will single step the program.
# Pressing Hold/Resume while a program is paused will return it to normal run mode.
# External Program Pause/Resume and Run/Step Buttons
# Pause/Resume Section
net pause-resume-btn and2.0.in0 and2.1.in0 hm2_5i25.0.7i76.0.0.input-04 #(this is your input btn)
net pause-on toggle2nist.0.is-on  and2.0.in1 and2.3.in1 <= halui.program.is-paused
net run-on and2.1.in1 <= halui.program.is-running
net pause-sig or2.0.in0 <= and2.0.out
net resume-sig or2.0.in1 <= and2.1.out
net toggle-ok toggle.0.in <= or2.0.out
net togglesig toggle2nist.0.in <= toggle.0.out
net toggleon halui.program.pause <= toggle2nist.0.on
net toggleoff halui.program.resume <= toggle2nist.0.off
# Run/Step Section
net run-step-btn and2.2.in0 and2.3.in0 hm2_5i25.0.7i76.0.0.input-03 #(this is your input btn)
net idle-on and2.2.in1 <= halui.program.is-idle
#notes:
# net pause.on and 2.3.in1 <= halui.program.is-paused
# and2.3.in1 was added in the net pause-on statement in Pause/Resume Section
net run-sig halui.mode.auto halui.program.run  <= and2.2.out
net step-sig halui.program.step <= and2.3.out
########### end pause/resume ####################################
23 Jul 2020 21:07 #175574 by rodw
Replied by rodw on topic Feature Request
Tommy, you need to google stack lights led
But I only paid $12 on Aliexpress.
  • thefabricator03
  • thefabricator03's Avatar
  • Visitor
  • Visitor
23 Jul 2020 21:51 #175579 by thefabricator03
Replied by thefabricator03 on topic Feature Request
I’m not sure I follow? I know it can select CPA mode for you, but the problem is you’ll lose the arc-ok signal after the first piece of expanded metal, and it’ll stop.
With my Hypertherm 125, when I set it to CPA mode, it does not lose its arc ok when cutting between sections of steel. The torch just stays on,
  • snowgoer540
  • snowgoer540's Avatar Topic Author
  • Moderator
  • Moderator
23 Jul 2020 22:19 #175580 by snowgoer540
Replied by snowgoer540 on topic Feature Request
In that video, it looks like you’re turning the torch on and then jogging it manually, correct?
  • thefabricator03
  • Visitor
  • Visitor
23 Jul 2020 22:26 #175581 by thefabricator03
Yeah that is correct, start the cut with F9 and with the CPA mode I can use it as a CNC controlled hand torch.
  • snowgoer540
  • Moderator
  • Moderator
23 Jul 2020 22:29 #175582 by snowgoer540
The arc-ok doesn’t matter/is not required in that scenario. We need the arc-ok signal for computer controlled movement.
I’m guessing if you tried the same thing to cut up that material pretending it was expanded metal with a CNC program it wouldn’t work.
  • snowgoer540
  • Moderator
  • Moderator
23 Jul 2020 22:39 #175583 by snowgoer540
Actually, I’m curious. What keys are you pressing to jog the table with the torch on? Because I’m pressing the arrow keys and it won’t move. It just cycles between the axis’ to touch off.
  • snowgoer540
  • Moderator
  • Moderator
23 Jul 2020 23:30 - 23 Jul 2020 23:47 #175585 by snowgoer540
Ok, I had some time to do some testing tonight before the lady gets home from work and we head to dinner. Have a few findings to report:
1. Arc-OK does not stay on in CPA mode, at least not with FineCut tips, I will try regular tips tomorrow or Saturday. As soon as it loses the arc-ok signal, it pauses.
2. I met Rod's Kangaroo. Circumstances: I forgot to enable the torch. Pressed F9, it ohmic sensed until infinity. Video Evidence . My stupidity, but maybe the software should let us know when we're trying to do something stupid?
3. I got my first lock-up of LinuxCNC tonight. Which, how do I kill it when that happens? I was trying to use the straight cut feature, clicked start cut, it tried 3 times for a valid arc, then paused, and locked up. I could still change the items in the run panel though, communication with the hypertherm worked. Eventually it crashed. Not sure if this is cut-recovery test related?
4. I had some issues where it wouldnt let me jog the table after the program was stopped for a few seconds afterward. This always was surrounding a paused condition (sometimes I was using F9, sometimes I was using the single cut from the Run panel) due to lack of valid arc, and hitting the max number of attempts. Again, not sure if this is cut-recovery related?
5. I also met a fire-breathing kangaroo. Not sure what happened here, but it tried to light off until infinity. Way past the 3 attempts, just kept trying and trying. More Video Evidence
(Edit)6. I cant jog after pressing F9.
Anyways, I posted this stuff here, because it was all found during the testing I was doing for the Arc-OK features I'm requesting. I'm beginning to fear being ousted for causing too much ruckus :unsure: :laugh:
Last edit: 23 Jul 2020 23:47 by snowgoer540.
  • thefabricator03
  • Visitor
  • Visitor
23 Jul 2020 23:45 #175586 by thefabricator03
Just the arrow keys. I press F9 then it touches off then goes to cut height then I can jog the machine as normal. I have not updated my machine since the beginning of the year so maybe a update has changed this?
24 Jul 2020 00:07 #175588 by rodw
When you are cutting in manual mode (no cnc) the machine won't care about the ArcOK. Its provided to tell the CNC controller what is going on. But if the controller (Plasmac) does not account for how the machine functions correctly then the ball is in the controller's court. I would not expect AcOK to be forced on for expanded metal mode when there is no arc. It will probably turn on when it is traversing material. It would be interesting to know that after your weekend adventure.
Time to create page: 0.220 seconds
