Feature Request
  • snowgoer540
  • snowgoer540's Avatar Topic Author
  • Moderator
  • Moderator
26 Jul 2020 12:14 #175891 by snowgoer540
Replied by snowgoer540 on topic Feature Request
I just pushed a few fixes that will hopefuly sort this out...
I also saw during testing this stuff that the breakaway didn't work during rapids, that should be sorted as well.
Good catch! I probably would have found that one the hard way, hopefully that wasn't your experience there. I'll probably bounce back and forth between testing the cut-recovery feature, and the mesh mode, if that's ok?
  • snowgoer540
  • Moderator
  • Moderator
26 Jul 2020 16:05 #175919 by snowgoer540
So this doesn't work correctly on my table. If I pause during a rapid move, change consumables still doesn't work, but what's worse than that, it comes to a rapid move and just stops for the rest of the LinuxCNC session. If I restart and go back in, everything works as normal provided nothing pauses.
Also, the cut-recovery button still doesn't bring up the cut-recovery stuff when it's paused (at least not during a rapid).
I'm at .146 and I ran the configurator for good measure like a good tester :)
27 Jul 2020 00:25 #175994 by phillc54
Replied by phillc54 on topic Feature Request
Is this all in the cut recovery branch?
  • snowgoer540
  • Moderator
  • Moderator
27 Jul 2020 01:36 #176000 by snowgoer540
Yes
27 Jul 2020 04:26 #176005 by phillc54
I can get this to happen from the breakaway switch but the pause button seems to work correctly.
27 Jul 2020 07:31 #176013 by phillc54
I pushed some changes to cut recovery
  • snowgoer540
  • Moderator
  • Moderator
27 Jul 2020 10:12 #176040 by snowgoer540
Interesting. I didn't get as far as to check breakaway, but if I paused during a rapid movement, I was pretty much hosed for the rest of the session.
  • snowgoer540
  • Moderator
  • Moderator
27 Jul 2020 10:13 #176041 by snowgoer540
Ok, so I'm understanding that this was specific to cut-recovery? The regular version of Plasmac and the mesh-mode branch are ok?
i hope you dont mind my jumping between test branches for testing?
27 Jul 2020 10:17 #176043 by phillc54
It would be nice (for me) to sort one branch out at a time.
  • snowgoer540
  • Moderator
  • Moderator
27 Jul 2020 10:18 #176044 by snowgoer540
Ok, no problem, just tell me which branch you want me to be on/testing, and I'll do that :)
Time to create page: 0.171 seconds
