Feature Request
11 Sep 2020 02:46 #181712 by phillc54
Replied by phillc54 on topic Feature Request
Oh, so in that particular case, the offset does not get cleared at Plasmac Max Height?
Technically it is never cleared at PLASMAC_MAX_HEIGHT. It is cleared at START_HEIGHT. If PLASMAC_MAX_HEIGHT was equal to START_HEIGHT then it would appear to cleared at PLASMAC_MAX_HEIGHT.
Where I said:
After reaching PLASMAC_MAX_HEIGHT any remaining OFFSET is cleared.
I actually meant:
After reaching PLASMAC_MAX_HEIGHT any remaining OFFSET is reduced each servo cycle at a rate that moves the Z axis at the Setup Speed value in the Config Panel. This moves the Z axis to the START_HEIGHT. When START_HEIGHT is attained the OFFSET will have been reduced to zero and then offsets will be disable..
  • snowgoer540
  • snowgoer540's Avatar Topic Author
  • Moderator
  • Moderator
11 Sep 2020 02:52 #181713 by snowgoer540
Replied by snowgoer540 on topic Feature Request
I actually meant:
Ok, believe it or not, I’m following along, that actually makes sense. I bet that python code is significantly more difficult than rezooming the preview :laugh:
11 Sep 2020 02:57 #181714 by phillc54
That is in the component so it is C and it is not that comlplex, just count towards zero at a rate of nnn then stop.
  • snowgoer540
  • Moderator
  • Moderator
11 Sep 2020 03:06 - 11 Sep 2020 03:06 #181715 by snowgoer540
Oh right C not Python... I have much to learn lol
Last edit: 11 Sep 2020 03:06 by snowgoer540.
Time to create page: 0.094 seconds
