Feature Request
07 Sep 2020 12:11 - 07 Sep 2020 12:13 #181142 by phillc54
Replied by phillc54 on topic Feature Request
You could set up a button to do that.
I have one on my pendant.
Edit: or after you jog up just give a quick jog down, it doesn't need to be exact.
Last edit: 07 Sep 2020 12:13 by phillc54.
  • snowgoer540
  • snowgoer540's Avatar Topic Author
  • Moderator
  • Moderator
07 Sep 2020 12:19 - 07 Sep 2020 12:20 #181143 by snowgoer540
Replied by snowgoer540 on topic Feature Request
I guess the thing that is confusing me is that if my soft limit is set to -0.2 below where home was established, why am I allowed to jog past it?
Edit: The other problem is that currently we are suggesting that people park the torch at the top before starting a program, that wont be the case in this case.
Last edit: 07 Sep 2020 12:20 by snowgoer540.
07 Sep 2020 12:24 #181145 by phillc54
No, your home is -0.2 below the soft limit.
Hence my mention of changing the docs earlier.:(
  • snowgoer540
  • Moderator
  • Moderator
07 Sep 2020 12:29 #181147 by snowgoer540
So then Home_Offset establishes the soft limit, and not Home? Maybe that's why I'm confused.
  • snowgoer540
  • Moderator
  • Moderator
07 Sep 2020 21:54 - 07 Sep 2020 21:58 #181180 by snowgoer540
So I've been thinking about this all afternoon while I was getting other things done...yes, I am a nerd :silly:
A few questions/ideas:
1. Why did this cause following errors for myself and mud? You are correct, it solved the problem, I tried early evening to break it again. It doesn't make the high pitch gear change at the bottom when it retracts anymore. Sometimes, it does "bounce" (overshoot where it should have stopped and then settle back down) near where the torch started, but otherwise it works fine.
2. I've been trying to think of a way to eliminate the need to make a manual jog down from the soft limit. I don't know what I don't know, so forgive me, but here's what I came up with:
a. Some sort of code that sets whatever the HOME value is set to as the "top of travel" for Plasmac purposes. Maybe that's more difficult than I am making it, but basically once you home, it sets the soft limit, then parks the torch at Home (-0.2"), and you can never jog past this while Plasmac is running.
b. Similar to a., but if you started the torch at the top of travel too close to the soft limit, instead of sending the torch back there, it would send it to -0.2 from the machine home coordinate.
Maybe none of that makes sense, but it's what I came up with while I was installing 2 gates :lol:
Last edit: 07 Sep 2020 21:58 by snowgoer540. Reason: accidentally hit post before I was finished writing
08 Sep 2020 02:20 - 08 Sep 2020 02:24 #181202 by phillc54
MAX_LIMIT set the soft limit. Your (new) Z is setup like:
Warning: Spoiler!
I don't understand the effect on following errors...:(
The way it works at the end of a cut is dependent on whether there is a following cut.
If a cut is following, at M5 it retracts to the safe height then waits at that height until the next M3 then it moves to probe or pierce height dependant on whether you are skipping IHS.
If there is no other cut then at M5 it retracts to the safe height. It stays at safe height until it gets a program stop signal. If there was a X/Y move before program stop it would do that at safe height. When it gets the program stop signal it moves to maximum height which is MAX_LIMIT - 5mm (0.1968") then it clears out any offsets. This makes it move to the height it was when the cut started. This may move the Z up or down depending on the relationship between the starting height and maximum height. This would be the "bounce" you refer to.
Unfortunately because we cannot control what the GUI jog buttons do it is out of our hands, we can only fit in with what is there. When (if) we get our own GUI then we would be able to do it "properly". There is no problem with jogging to the top then jog down a "bit". You may or may not get a "bounce" at the end of the final cut but it is not an issue even though it may look a bit ugly.
Last edit: 08 Sep 2020 02:24 by phillc54.
  • snowgoer540
  • Moderator
  • Moderator
08 Sep 2020 11:46 #181253 by snowgoer540
Well, at least we're in good company lol Thank you for the picture, that was super helpful!
So I think I get what it does, but I don't fully understand why starting from a point near the soft limit causes problems. If it clears its offset 5mm from the soft limit, wouldn't mean that it wasn't near the offsets when offsets were being used? So, instead of doing the last move to park the torch wherever it was when the whole works started, why cant we just leave it at MAX_LIMIT - 5mm? Then, it would seem, it wouldn't matter where you started the cut from?
Guess I need to up the Python anty so I can chip in on this :laugh: I was just trying to think of a way to save the user (namely me) from themselves.
08 Sep 2020 12:17 #181262 by phillc54
It is not the starting near it, it is the finishing near it.
It moves to soft limit -5mm then it clears the remaining offset. That is the move that puts it back where it started from.
  • snowgoer540
  • Moderator
  • Moderator
08 Sep 2020 12:32 #181269 by snowgoer540
My head is officially a pretzel. I thought you were saying that it moves the Z axis to whatever the MAX_LIMIT is minus 5mm, as in a position. So what it really does is move the MAX_LIMIT down by 5mm, and then goes to the soft limit, and then clears the offset?
Isn't that the same thing as moving the Z axis near the soft limit with offsets applied?
And then I understand even less now why ending near that point, but away from the original soft limit fixes the issue.
I apologize, I'm really trying to understand what's going on, but it's not clicking. Maybe it doesn't necessarily need to click, but it makes it hard to provide input (which maybe isn't needed at this point) until I understand what is happening... Maybe is there a place I can read up on the offset method you're using that might make it clearer?
08 Sep 2020 12:41 #181272 by phillc54
I'll attempt a better description tomorrow when the brain is a it fresher.
Time to create page: 2.872 seconds
