Feature Request
07 Sep 2020 04:17 #181091 by phillc54
Replied by phillc54 on topic Feature Request
Oops, I am blind B)
Can you try with it with [JOINT_3]HOME = -0.2
I learnt something today from your config, previously I was always under the assumption that HOME_OFFSET was required to be within or equal to the soft limits. Now I need to fix the PlasmaC docs...
  • snowgoer540
  • snowgoer540's Avatar Topic Author
  • Moderator
  • Moderator
07 Sep 2020 10:34 #181113 by snowgoer540
Replied by snowgoer540 on topic Feature Request
Oops, I am blind B)
Sure can, do I need to update or anything first? Or just change that value?
Well if whatever I did in my config seemed like a stroke of brilliance on my part I can assure you it was an accident...it was :)
We need to find a way to keep those in sync... or maybe you can send me the changes and I will work them into the doc I am editing? Hopefully we can avoid my editing a doc that's too far out of date haha. Open to suggestion.
07 Sep 2020 10:39 #181115 by phillc54
Yep, just change the value.
Shoot, I forgot about that. I'll think of something...
  • snowgoer540
  • Moderator
  • Moderator
07 Sep 2020 11:02 #181124 by snowgoer540
Changed to -0.2. Seemed to work fine now!
Why does that make a difference??
07 Sep 2020 11:08 #181129 by phillc54
As Dewey pointed out to me a while ago, when offsets are active the axis should not go near the soft limits. I set the maximum Z offset to 5mm (0.0196") below X max. In your config the Z home was 0.001" below the Z max while still active.
I will need to fix the docs and maybe have a popup warning when LinuxCNC is loaded when it finds the settings may cause issues.
  • snowgoer540
  • Moderator
  • Moderator
07 Sep 2020 11:17 #181132 by snowgoer540
One thing I dont quite understand is when I home my Z now, it parks it -0.2 down, but I can jog up past that. To 0.050" below the limit switch.
my X and Y are set up similarly to how Z was. Do they need to be changed?
07 Sep 2020 11:25 - 30 May 2021 06:14 #181136 by phillc54
[One thing I dont quite understand is when I home my Z now, it parks it -0.2 down, but I can jog up past that. To 0.050" below the limit switch.
Because that is the max limit. If you start a program from that position then you will likely see this issue.
No they should be fine.
Last edit: 30 May 2021 06:14 by phillc54.
  • snowgoer540
  • Moderator
  • Moderator
07 Sep 2020 11:54 #181137 by snowgoer540
It doesn't appear to cause the issue for whatever reason. But I don't want to tempt fate, so how do I prevent it from letting me park it that high then? Because I'm used to jogging it to the top before doing a run.
I'm not fully wrapping my head around what's going on here, for some reason.
07 Sep 2020 12:03 - 07 Sep 2020 12:04 #181138 by phillc54
You could just home your machine and leave the Z axis where it is.
It is probably my explanation...:)
Edit: do you use a pendant?
Last edit: 07 Sep 2020 12:04 by phillc54.
  • snowgoer540
  • Moderator
  • Moderator
07 Sep 2020 12:08 #181141 by snowgoer540
True, but I often jog the torch down so I can see where it's going to end up when I'm touching off. When I jog back up, it doesnt stop at the -0.2, goes happily up to where the offset is from homing.
No pendant here..yet :evil:
Time to create page: 0.202 seconds
