Feature Request
- phillc54
- Thank you received: 2100
25 Aug 2020 19:21 - 25 Aug 2020 19:22 #179471
by phillc54
Replied by phillc54 on topic Feature Request
Well that is bizarre, you did do a git pull?
What version does it report?
Last edit: 25 Aug 2020 19:22 by phillc54.
- snowgoer540
- Thank you received: 907
25 Aug 2020 19:36 #179472
by snowgoer540
I actually didn't since last I added the two lines today. I just changed repositories as reported.
I can try that... maybe that's the culprit.
0.165
Replied by snowgoer540 on topic Feature Request
0.165
- phillc54
25 Aug 2020 19:38 #179473
by phillc54
0.165 is the latest
- Thank you received: 4155
25 Aug 2020 19:53 #179476
Replied by rodw on topic Feature Request
Once you clone a git repository, the git pull command syncs everything. If you checkout another branch, it syncs your source to that branch so you should not have any problems that require starting again.
If say you wanted to try another repository say one of mine, you could clone my repository github.com/rodw-au/linuxcnc into a new folder say , linuxcnc-rodw
Then you might want to checkout my arc-radius branch ( its a bit behind) and make sure you use the correct rip-environment script. Then running Linuxcnc from the command prompt should open the right version of the software.Using different rip-environment scripts should swap between versions.
This pull request outlines what this branch is trying to do but the devs want some changes.
github.com/LinuxCNC/linuxcnc/pull/900
I will wait until 2.8 is done and dusted cos Andy has been guiding me in the background.
- snowgoer540
25 Aug 2020 20:40 - 26 Aug 2020 04:52 #179478
by snowgoer540
So I hit it with a big hammer.
Blew away the linuxcnc-dev folder contents, git cloned it back in there, ran the stuffs, compiled, and it's back to Torch Enabled and Disabled. It's odd to me that nothing I did fixed that. I tried every combination I could think of. Git still baffles me. It probably wanted to hang onto that file since I edited it, I'm not sure how to tell it to let it go though.
Rod, that sounds interesting, I may try to have a second RIP version of your branch and check it out.
At any rate, I've got it back to "normal" now. I'm now afraid to change it from enabled to on and disabled to off lol. It's going to irk me as to why it did that.
Last edit: 26 Aug 2020 04:52 by snowgoer540.
- snowgoer540
30 Aug 2020 17:18 - 01 Sep 2020 06:39 #180112
by snowgoer540
As it turns out, we were both wrong. Watched their install video today out of curiosity. This is the card they point you to to do the ohmic sensitivity adjustment, which they do with a pot screw, and it's also the THC.Dang, good eye man! Guess that's an ohmic card all the way to the right... looks to be of their own creation.
Last edit: 01 Sep 2020 06:39 by snowgoer540.
- snowgoer540
01 Sep 2020 06:38 #180313
by snowgoer540
I'm trying to help a friend diagnose his table.
He swears his config tab says v0.169. However his <machine_name>_config.cfg says v0.161. Is that possible?
He's having some odd issues, and honestly I wonder if his setup is hosed up. Scribing doesnt work anymore (he says Plasmac strips it out of the g-code). Previously Ohmic3 wouldnt work when Ohmic2 did, but now even Ohmic2 doesnt work, etc.
Was just trying to start simple first. He has really terrible internet service. I'm wondering if getting rid of the build bot version, and putting him on a RIP 2.8 version wouldn't be a better idea.
I attached some of his files to have a quick look, I dont see anything out of place, and the table was working fine previously.
- phillc54
01 Sep 2020 06:58 - 01 Sep 2020 06:59 #180319
by phillc54
I won't get a chance to look at the config until tomorrow (it is Jameson time)
First up get him to open a terminal and run man plasmac which will show a version number.
If it is v0.169 get him to do a manual upgrade from:
/usr/share/doc/linuxcnc/examples/sample-configs/by_machine/plasmac/configurator.py
that should at least make sure all files are in sync.
If it is not v0.169 get him to do the sudo apt update then then sudo apt dist-upgrade
I wouldn't think so, as <machine_name>_config.cfg is where the config tab reads the version number. Maybe he has a mix of configs???He swears his config tab says v0.169. However his <machine_name>_config.cfg says v0.161. Is that possible?
Last edit: 01 Sep 2020 06:59 by phillc54.
- snowgoer540
01 Sep 2020 07:40 #180326
by snowgoer540
Thanks, I will have him check those things out. That gives us a place to start, I suspect his files got out of sync as well.
Have one for me!(it is Jameson time)
- snowgoer540
01 Sep 2020 17:47 #180370
by snowgoer540
Ok, so working through some of this. He's definitely on version .169.
Learning more about the problems, I think the Ohmic problem is a loose wire (he recently transported the table).
However, the scribing problem is, I believe, due to plasmac_G-Code.py stripping out the M3 $1 S1 commands. I confirmed with a test file he sent me that my machine does the same thing. I looked and the G-Code.py was updated 21 days ago, in my brief look I didnt see anything that would have broken it, but mostly I think I should stick to testing only
I'm guessing either not many people scribe, or those who do don't update. I attached a file for your convenience.
Time to create page: 0.253 seconds
