Feature Request
- snowgoer540
- Thank you received: 907
Have you tried perpendicular leadins on those internal features?
I think at one point I did, I can definitely try again though.
That particular cut file flamed out on literally every arc.
- phillc54
- Thank you received: 2100
- snowgoer540
Am I reading it correctly, the holes are 0.25" (6.35mm) and the slots are the same width.
From the model, both are .3".
- phillc54
OK, I didn't allow for kerf width.
- Thank you received: 4150
I seem to remember Jim Colt saying to use perpendicular leadins. I trued arcs and gave up then never tried again.
- snowgoer540
Oh right, yea I didnt think of it either. 5am here, no coffee yet, about to leave for work
I'll switch over for sure! I watched a few Jim Colt videos in my expanded metal research. He doesnt seem to explain how at least MaverickCNC handles expanded metal other than "turn off the THC". They must just ignore the arc OK though.
- phillc54
Do Powermax's keep the Arc OK signal on during CPA mode?
- snowgoer540
So that was my initial impression of how they would work, however that's not been my experience. All of the issues I've mentioned were most recently done in Mode 2 (CPA Mode). As soon as the torch flamed out, the machine paused. I supposed there could be something wrong with my power unit, but I would think it's highly unlikely as it's brand new otherwise.Do Powermax's keep the Arc OK signal on during CPA mode?
All the manual says is:
For cutting expanded metal, grates, metal containing holes, or any job that requires a continuous pilot arc. Using this mode to cut standard metal plate reduces consumable life.
- phillc54
I think Stefan did some manual single cuts in CPA mode to cut up some skeletons.
All the manual says is:For cutting expanded metal, grates, metal containing holes, or any job that requires a continuous pilot arc. Using this mode to cut standard metal plate reduces consumable life.
linuxcnc.org/docs/2.8/html/plasma/plasma...ide.html#_single_cut
He didn't mention any flameouts.
- snowgoer540
Perhaps manual mode is coded to ignore the loss of arc-ok? It mentions you cant move until you receive an arc-ok signal, but makes no mention of how a loss is handled.
I can do whatever specific testing you'd like this weekend as I'm off tomorrow-Sunday, and the girlfriend works all weekend, leaving me free to tinker in the garage at my leisure
