Plasmac 7i76e thcad 10 will not probe
- Thank you received: 7501
02 Aug 2020 07:35 #176864
Replied by tommylight on topic Plasmac 7i76e thcad 10 will not probe
Why two topic with the same subject???
I just moved the other one to PlasmaC !!!!!!!!!!!!!
- phillc54
- Thank you received: 2100
02 Aug 2020 07:36 - 02 Aug 2020 07:37 #176865
by phillc54
Replied by phillc54 on topic Plasmac 7i76e thcad 10 will not probe
Tom, I think after he saw my reply about using the PlasmaC section he started one there as well.
Edit: the other one could probably be deleted.
Last edit: 02 Aug 2020 07:37 by phillc54.
02 Aug 2020 08:07 #176875
Move this topic and change the title,
Move the relevant posts one by one from the other topic to this one.
That is the procedure to clean this up.
For future reference : No double posting !
02 Aug 2020 08:10 #176876
And it got messed up due to timestamps !
- Foldaround
02 Aug 2020 18:35 #176920
by Foldaround
Replied by Foldaround on topic Plasmac 7i76e thcad 10 will not probe
Ok I changed my .ini file to match your settings and it didn't crash but some other odd things happened.
My THC voltages were all over the place so I checked my encoder velocity in .hal show and it looked good so I then checked my arc-voltage scale and offset settings and they were back to default even tho the .hal file shows my custom ones.
I tried to change them live in hal show and they wouldn't take.
The good news is I disabled the THC and tried a test cut and IT WORKED!!!
MY FIRST CUT!!
So probing is working but my settings are being ignored.
MY FIRST CUT!!
The following user(s) said Thank You: dvn4life1972
- Foldaround
02 Aug 2020 18:41 #176922
by Foldaround
Oh man Im sorry tommylight ... I figured the other post would just get deleted so I started a new one with the same name name in the correct location so phill could find it.
- Foldaround
02 Aug 2020 18:53 #176924
by Foldaround
In addition when linuxcnc first starts it looks like my voltages are OK for about 1 second and then they must go back to default settings.
This shows up in terminal during that time:
Axis window is 930 x 664
62914563
31457283
67108867
69206019
62914563
31457283
67108867
69206019
02 Aug 2020 20:38 #176932
No worries, i do not mind it, but it makes a mess for new users.Oh man Im sorry tommylight ... I figured the other post would just get deleted so I started a new one with the same name name in the correct location so phill could find it.
- phillc54
02 Aug 2020 23:18 #176959
by phillc54
Those numbers are just Axis reporting the ID od the GladeVCP panels it is loading, that is normal. Actually it is a good sin, telling you the four panels have loaded.
The config you posted originally was incomplete in that it did not have all the cfg files. Are you setting the Voltage Offset and the Voltage Scale in the config panel and then saving them?
62914563
31457283
67108867
69206019
- Foldaround
03 Aug 2020 00:52 #176975
by Foldaround
I have the voltage scale and offset in the .hal file near the bottom.
The config folder I sent was everything I had simply zipped it and uploaded. Unless you needed the base folder as well (the one I used as a baseline for plasmac) Do you know what program is responsible for creating the missing files? PnCConf?
Time to create page: 0.584 seconds
