Plasmac z axis touch n go
02 Aug 2020 10:01 #176893 by benbenben
Plasmac z axis touch n go was created by benbenben
hello everyone i am fiddeling a while on plasmac, and this problem i was not able to figure out.
1. homimg all axes
2. jogging z just below the lowest slat
3. zeroing z axis
4. homing z
5. probe testing
a. torch moves down
b. hits the material to cut
c.z axis carriage moves further towards material to cut
d. proximity sensor recognizes passing carriage, and keeps moving after the trip point until, i guess, the probe height specified in config is reached, then it sits there without moving up until the button timeout occurs and moves back to home position
e. tripping of prox. Sensor can be seen in plasmac float switch indicator light
6. when proximity sensor is triggered a second time e.g. with a screwdriver while it sits on the surface“wating for the time out“ it moves further down and error messages get displayed that soft limits are exedeed
any idea what to change?
Best
Ben
ini from z axis
[AXIS_Z]
# set to double the value in the corresponding joint
MAX_VELOCITY = 100.0
MAX_ACCELERATION = 1500.0
# shares the above two equally between the joint and the offset
OFFSET_AV_RATIO = 0.5
MIN_LIMIT = -60.0001
MAX_LIMIT = -15.0001
[JOINT_2]
TYPE = LINEAR
HOME = -58.00
MAX_VELOCITY = 50.0
MAX_ACCELERATION = 750.0
STEPGEN_MAXACCEL = 937.5
SCALE = 50.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = -47.00
HOME_SEARCH_VEL = -40.00000
HOME_LATCH_VEL = 10.00000
HOME_SEQUENCE = 0
02 Aug 2020 17:58 #176955 by benbenben
Replied by benbenben on topic Plasmac z axis touch n go
i was thinking, maybe its the switch debounce wich smoothes the signal from the first trip to much? ill try and remove the debounce tomorrow and report back.
02 Aug 2020 18:11 #176958 by phillc54
Replied by phillc54 on topic Plasmac z axis touch n go
Home should be near the top of travel, so something like -16 rather than -58.
Can you compress the config directory and post it.
03 Aug 2020 09:43 - 03 Aug 2020 14:25 #177046 by benbenben
Hello Phil,
attached the config.
"Home should be near the top of travel, so something like -16 rather than -58."
the torch tip would be way below the slats so i made the travel max -60, then home -58 and minimum travel -15, this is where the torch tip is below the slats. so the farthest point away from the slats is -60.
yesterday evening i changed the z coordinate system into positive hoping it helps but it didnt. So dont wonder if the .ini entries for z now look different. from yesterdays post
File Name: plasmav1_b...n.tar.gz
File Size:48 KB
Ben
edit:
i made the following observation, z axis is at home position 25mm, i set the probing height to 5mm, z axis drives to 5mm mark and then sits there until time out and drives back up. only when i set the probing height to a travel value where the float switch is triggerd the axis goes into probing speed but drives until end of minimum travel, waits for time out and retracts,
Last edit: 03 Aug 2020 14:25 by benbenben.
03 Aug 2020 20:04 #177145 by phillc54
Max limit needs to be greater than Min Limit, if you want your Max Limit to be -60, then you min limit would need to be -105.
I would stick to the 0.0001 and 45.0001 you have in the posted plasmav1.ini, to me it is easier to comprehend.
Does the z axis move up when you jog with the + button?
Where is your home switch in relation to the max limit?
04 Aug 2020 03:39 - 04 Aug 2020 04:56 #177196 by benbenben
Hello Phil,
z axis goes down, towards slats when pressing +,the home switch is close to max limit.
...now i inverted the hal pin so that when pressing + the axis moves up, changed the sign of home search vel and changed the home offset that the axis can be homed proper and now by pressing probe test the axis doesent move anymore but homing and jogging works.
[AXIS_Z]
MAX_ACCELERATION = 400.0
MAX_LIMIT = 45.000
MIN_LIMIT = 0.000
[JOINT_2]
TYPE = LINEAR
HOME = 44.00
MIN_LIMIT = 0.000
MAX_LIMIT = 45.000
MAX_VELOCITY = 50.0
MAX_ACCELERATION = 200.0
SCALE = 50.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 45.00
HOME_SEARCH_VEL = 40.00000
HOME_SEQUENCE = 0
Last edit: 04 Aug 2020 04:56 by benbenben.
04 Aug 2020 03:49 - 04 Aug 2020 03:51 #177197 by phillc54
which HAL pin?
Is the move up/down signal during probing controlled by the z direction/pulse pins or by the up/down pins defined in the configurator for THC?
It is done internally by usin offsets.
Your home offset and home would then need to be close to 45
Last edit: 04 Aug 2020 03:51 by phillc54.
04 Aug 2020 08:17 #177241 by benbenben
which HAL pin?
Inverted the z direction pin, so that when pressing + the axis moves up. Right now I am not on the machine but what's bugging me is, that that was probably a mistake, instead of inverting the pin to move the z axis up when pressing +, I should have modified the z parameter for home, home offset and home search vel. That this fixes the movement. What I observed is, the z axis is not moving down on probing when the probe height is set to the maximum z hight. When I move the z axis down a bit and hit probing the z axis moves up. So i guess the error is in the setup of my home, homeoffset and home search vel and latching direction
04 Aug 2020 18:00 #177300 by phillc54
The ways to reverse motor direction are:
1. reverse either of the two motor coils, but only one coil not both.
2. change the sign of the SCALE for that joint in the ini file, so if the scale was 50 make it -50
changing the scale is the way I normally do it
05 Aug 2020 07:16 #177387 by benbenben
Thank you Phil,
I am away for 2 weeks now, when I am back. I test it out and report back.
Time to create page: 0.910 seconds
