Error on first launch PlasmaC ???
03 Aug 2020 20:36 #177084 by kramerda
Error on first launch PlasmaC ??? was created by kramerda
Hi guys,
I have a working system (can jog XYZ). Ran Configurator/create/launched linuxcnc with errors shown in attached screen shot.
Something to do with Ipv6, but Mesa 7i76e is working fine connected via ethernet Ipv4. Screen that launches is not Plasma screen but base machine configuration ?????
Help and comment most appreciated.
03 Aug 2020 20:38 #177088 by snowgoer540
Replied by snowgoer540 on topic Error on first launch PlasmaC ???
I vaguely remember seeing something similar before. Can you try disabling your wifi, and then starting LinuxCNC?
03 Aug 2020 20:50 #177090 by kramerda
Replied by kramerda on topic Error on first launch PlasmaC ???
OK - but linuxcnc is running on an AMD/MSI computer that has no wifi - I manually connect an ethernet cable to my router - which is now not connected to the internet. Ethernet cable is only connected to the Mesa 7i76.
Other note - when I rerun configurator using same ini file to reconfigure - it hangs. ????
  • Moderator
  • Moderator
03 Aug 2020 21:12 #177095 by tommylight
Replied by tommylight on topic Error on first launch PlasmaC ???
Those errors are pertaining to IPV6 ( Internet Protocol Version 6 ), and can be ignored and usually do not cause the configuration to fail.
We need the Debug part of the error.
03 Aug 2020 21:31 #177106 by kramerda
thanks tommylight - offsite for an hour - back soon
03 Aug 2020 23:09 #177122 by kramerda
Heres INI, print, and screen shot of full error message. debug file only said "stopping real-time threads" and unloading hal components".
File Name: linuxcnc_p...8-03.txt
File Size:1 KB
File Name: densplasma...8-03.txt
File Size:9 KB
03 Aug 2020 23:24 #177124 by phillc54
Replied by phillc54 on topic Error on first launch PlasmaC ???
You have in your machine hal file
net din-00     <=  hm2_7i76e.0.7i76.0.0.input-06
and you also asked the configurator to connect something to that pin as well, it a pin can only be connected once.
It will appear in densplasmaaug3d_connections.hal
03 Aug 2020 23:50 #177126 by snowgoer540
Whoops. That's what I get for looking on my phone. I saw the IPv6 stuff and didnt read any further. :blush:
04 Aug 2020 00:04 #177130 by kramerda
Thank you - I missed that one by a mile - I actually thought they should match. I'll comment out the duplicates for the other inputs and outputs in the .hal as well and give it a go. :)
Where should the encoder velocity, thcad input, go (hal - connection from the configurator Arc voltage line?
04 Aug 2020 00:07 #177131 by phillc54
That should also only be in your connections.hal file
Time to create page: 0.120 seconds
