Set the current for the plasma generator from the Plasmac
- hermann1976
- Thank you received: 17
16 Aug 2020 18:51 #178424
by hermann1976
Set the current for the plasma generator from the Plasmac was created by hermann1976
Hello,
I would like to ask whether it is still possible to transfer the current value from the cutting parameters to a plasma generator via a 0-10V analog output?
I have a Telwin Plasma 100 which can take the current strength via a 0-10V input.
According to the field description, this is not intended in plasmac. Is there a reason for that? Can it still be activated?
Many thanks.
Hermann
Many thanks.
Hermann
- phillc54
- Thank you received: 2100
16 Aug 2020 22:57 #178432
by phillc54
Replied by phillc54 on topic Set the current for the plasma generator from the Plasmac
PlasmaC only uses the cut current if you have Powermax RS485 comms enabled.
You could use the associated HAL pin to do what you wanted, there are two pins available:
1. a float pin named plasmac_run.cut-current-f
2. a S32 pin named plasmac_run.cut-current-s
- Thank you received: 5335
16 Aug 2020 23:38 - 16 Aug 2020 23:46 #178435
Replied by PCW on topic Set the current for the plasma generator from the Plasmac
I think the OP has a 7I76E so you would link the float pin to spinout
net run_current plasmac_run.cut-current-f => hm2_7i76e.0.7i76.0.0.spinout
You would also have to enable the spindle output (this may be automatic if you are using spindle-on for plasma control already). in any case hm2_7i76e.0.7i76.0.0.spinena must be true for the analog out to work
and set the scale in the INI file
[SPINDLE_0]
OUTPUT_SCALE = 100
OUTPUT_MIN_LIMIT = 0
OUTPUT_MAX_LIMIT = 100
(This is assuming 10V = 100A and that plasmac_run.cut-current-f is scaled in Amps and a pncconf created hal/ini file set)
[SPINDLE_0]
OUTPUT_SCALE = 100
Last edit: 16 Aug 2020 23:46 by PCW.
- hermann1976
17 Aug 2020 08:19 #178470
by hermann1976
Replied by hermann1976 on topic Set the current for the plasma generator from the Plasmac
Thanks a lot, i will test it soon as possible.
- Thank you received: 4154
17 Aug 2020 10:27 #178476
Replied by rodw on topic Set the current for the plasma generator from the Plasmac
PCW, thats a cool idea. I wonder how easy it would be to replace the current knob on a thermal dynamics with a digital pot controlled with the spindle?
- taloot
- Thank you received: 89
17 Aug 2020 16:06 - 17 Aug 2020 16:10 #178485
by taloot
also i dont think 0-10v will be stable and amp stability important to control the arc density
Replied by taloot on topic Set the current for the plasma generator from the Plasmac
good idea but u will gain nothingPCW, thats a cool idea. I wonder how easy it would be to replace the current knob on a thermal dynamics with a digital pot controlled with the spindle?
Last edit: 17 Aug 2020 16:10 by taloot.
17 Aug 2020 16:42 #178489
I don't know, it depends on whether the control potentiometer is just setting a DC voltage
If it is, it should work
17 Aug 2020 16:49 #178490
Actually with the Telwin you gain something quite significant, the ability to change the current in real time
Why do you think the current control would be unstable? The 7I76E analog output stability depends
chiefly on the 10V supply stability (Whether or not you could replace the Hypertherms POT with a voltage
source remains unknown)
- Thank you received: 7501
17 Aug 2020 17:45 #178495
Replied by tommylight on topic Set the current for the plasma generator from the Plasmac
I asked a friend about 8 months back to borrow his Cebora 150A plasma exactly for testing that, but he chickened out !PCW, thats a cool idea. I wonder how easy it would be to replace the current knob on a thermal dynamics with a digital pot controlled with the spindle?
- hermann1976
17 Aug 2020 19:30 #178516
by hermann1976
maybe that's helpful...
Time to create page: 0.196 seconds
