Jog buttons missing
- mariusl
20 Aug 2020 21:06 #178878
by mariusl
Regards
Marius
www.bluearccnc.com
Jog buttons missing was created by mariusl
Hi
I just noticed that all my jog buttons are missing. The step increment selection buttons are visible but no jog buttons. Any suggestions?
Regards
Marius
www.bluearccnc.com
- phillc54
- Thank you received: 2100
20 Aug 2020 23:10 #178885
by phillc54
Replied by phillc54 on topic Jog buttons missing
What GUI?
- mariusl
21 Aug 2020 05:59 #178896
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Jog buttons missing
Sorry, Gmoccapy. I just assumed that everyone uses that
Regards
Marius
www.bluearccnc.com
- phillc54
21 Aug 2020 06:07 #178898
by phillc54
I just tried then with a Run Panel and then with a Run Tab and works OK here. That is on a sim.
Not me, I use Axis.Sorry, Gmoccapy. I just assumed that everyone uses that
- Thank you received: 7501
21 Aug 2020 06:26 #178901
Replied by tommylight on topic Jog buttons missing
+1Not me, I use Axis.
- mariusl
21 Aug 2020 07:07 #178904
by mariusl
Regards
Marius
www.bluearccnc.com
My sim also has the jog buttons but not the installed run version. I did not add or change anything in the INI file.
I am sure that those buttons are standard for the Gmoccapy screen. Does the PlasmaC installation require any mods to the jog buttons?
Regards
Marius
www.bluearccnc.com
- phillc54
21 Aug 2020 07:08 - 21 Aug 2020 07:11 #178905
by phillc54
Could you post your ini file.
Edit. I am testing on 2.8
No, none at all. Very odd...My sim also has the jog buttons but not the installed run version. I did not add or change anything in the INI file.
Last edit: 21 Aug 2020 07:11 by phillc54.
- mariusl
21 Aug 2020 07:23 #178907
by mariusl
Regards
Marius
www.bluearccnc.com
Regards
Marius
www.bluearccnc.com
- phillc54
21 Aug 2020 07:27 - 21 Aug 2020 07:28 #178908
by phillc54
Try changing:
to:
Edit. If you home the machine in the original format the buttons will show, it hides joint buttons.
KINEMATICS = trivkins coordinates=XYYZ kinstype=BOTHto:
KINEMATICS = trivkins coordinates=XYYZEdit. If you home the machine in the original format the buttons will show, it hides joint buttons.
Last edit: 21 Aug 2020 07:28 by phillc54.
The following user(s) said Thank You: Sadmeatball
- mariusl
21 Aug 2020 09:18 #178911
by mariusl
Regards
Marius
www.bluearccnc.com
That worked fine thanks. I dont know if I want to drive the slave Y axis in joint mode. The machine has only one limit switch fitted. I might have to redo the config.
Regards
Marius
www.bluearccnc.com
Time to create page: 0.090 seconds
