Jog buttons missing
  • mariusl
  • mariusl's Avatar Topic Author
  • Platinum Member
  • Platinum Member
20 Aug 2020 21:06 #178878 by mariusl
Jog buttons missing was created by mariusl
Hi
I just noticed that all my jog buttons are missing. The step increment selection buttons are visible but no jog buttons. Any suggestions?
Regards
Marius
www.bluearccnc.com
20 Aug 2020 23:10 #178885 by phillc54
Replied by phillc54 on topic Jog buttons missing
What GUI?
  • mariusl
  • Platinum Member
  • Platinum Member
21 Aug 2020 05:59 #178896 by mariusl
Replied by mariusl on topic Jog buttons missing
Sorry, Gmoccapy. I just assumed that everyone uses that
Regards
Marius
www.bluearccnc.com
21 Aug 2020 06:07 #178898 by phillc54
Not me, I use Axis.
I just tried then with a Run Panel and then with a Run Tab and works OK here. That is on a sim.
  • Moderator
  • Moderator
21 Aug 2020 06:26 #178901 by tommylight
Replied by tommylight on topic Jog buttons missing
Not me, I use Axis.
+1
  • mariusl
  • Platinum Member
  • Platinum Member
21 Aug 2020 07:07 #178904 by mariusl
My sim also has the jog buttons but not the installed run version. I did not add or change anything in the INI file.
I am sure that those buttons are standard for the Gmoccapy screen. Does the PlasmaC installation require any mods to the jog buttons?
Regards
Marius
www.bluearccnc.com
21 Aug 2020 07:08 - 21 Aug 2020 07:11 #178905 by phillc54
No, none at all. Very odd...
Could you post your ini file.
Edit. I am testing on 2.8
Last edit: 21 Aug 2020 07:11 by phillc54.
  • mariusl
  • Platinum Member
  • Platinum Member
21 Aug 2020 07:23 #178907 by mariusl
Also on 2.8 so far I know.
File Name: plasma.ini
File Size:10 KB
Regards
Marius
www.bluearccnc.com
21 Aug 2020 07:27 - 21 Aug 2020 07:28 #178908 by phillc54
Try changing:
KINEMATICS = trivkins coordinates=XYYZ kinstype=BOTH
to:
Edit. If you home the machine in the original format the buttons will show, it hides joint buttons.
Last edit: 21 Aug 2020 07:28 by phillc54.
The following user(s) said Thank You: Sadmeatball
  • mariusl
  • Platinum Member
  • Platinum Member
21 Aug 2020 09:18 #178911 by mariusl
That worked fine thanks. I dont know if I want to drive the slave Y axis in joint mode. The machine has only one limit switch fitted. I might have to redo the config.
Regards
Marius
www.bluearccnc.com
Time to create page: 0.184 seconds
