PID settings for THC
- phillc54
- Thank you received: 2100
08 Sep 2020 19:02 #181341
by phillc54
Replied by phillc54 on topic PID settings for THC
I had a look and in Materialverter it defaults to Off if it doesn't exist in the input file. If it does exist in the input file then it follows what is set in the file.
I'll change the default to On.
- Thank you received: 4156
08 Sep 2020 22:26 #181357
Thats a good idea. Thanks. So now I'll have to upgrade!
Replied by rodw on topic PID settings for THC
- mariusl
09 Sep 2020 01:41 #181375
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic PID settings for THC
That will be good. I agree with Rod, the THC should always be on and if someone finds the need to turn it off before or during cutting, then it must be done in gcode or manually.I had a look and in Materialverter it defaults to Off if it doesn't exist in the input file. If it does exist in the input file then it follows what is set in the file.
Regards
Marius
www.bluearccnc.com
Time to create page: 0.359 seconds
