- Thank you received: 14
kramerda wrote: Just a long shot but I have a similar machine and the torches that come with the machine need at least 90 psi into machine and at least 55 psi flowing out of torch to keep blow back start working. ???
snowgoer540 wrote: Would you mind posting your config here?.
That has to be done while the air is on, while the torch is blowing air. Some plasma cutters have a switch just for that.little_sparky wrote: I might double check the plasma cutters own pressure gauge in the morning to see if i need to adjust.
