Valid Arc Lost 2
6 years 1 month ago - 6 years 1 month ago #182353 by little_sparky
Replied by little_sparky on topic Valid Arc Lost 2
Okay so after taking in all the advice listed above, I think i'm almost there!
So working through tommy's list this is what I did.
Firstly, I turned down the amps on the everlast plasma cutter from 42 amps to 35 and slowed down my cut feedrate. I thought this might help with power fluctuations.
Secondly, I went out and got another good 2 stage air filter, giving me 4 in total now. I am also toying with the idea of adding my own homemade wall mounted desiccant filter, does anyone have any experience or recommendations with this?
Thirdly, I double checked every wire to see if there were any broken wires.
Next I played around with the cut speed and I ended up dropping it about 40% (seems large but I also dropped the amps too)
After all this, and Rod's new arc ok resistor resistor blowing away the built up oxide, I am getting reliable cuts with about 30 minutes of cut time not throwing up a single error yet.
Thanks for all your help guys and fingers crossed I dont have to reply to this topic again!
Last edit: 6 years 1 month ago by little_sparky.
The following user(s) said Thank You: phillc54, tommylight, rodw, Aciera
6 years 1 month ago #182390 by rodw
Replied by rodw on topic Valid Arc Lost 2
Great teamwork Sparky! Thanks for the update.
6 years 1 week ago #187051 by benbenben
Replied by benbenben on topic Valid Arc Lost 2
Hello all,
I just came across this thread, and didnt wanted to open a new one.
I have a simple ebay plasma cutter and 2 different machine torches. My Plasma cutter has no communication with PlasmaC or any machine periphery whatsoever. Even the Arc OK is "bridged" so its constantly "OK". While cutting the same part using torch 1, it goes trough without any trouble, using torch 2, with the same gcode, i get multible valid arc lost errors. Does someone has an explanation for that? Also on torch 2 you can observe the arc lost, the torch is sputtering and then the program stops due to the error. But my question is how can plasma C sense that without any imput data from the plasma? Also its not the gcode since it works on torch 1 and not on torch 2 psychic?
6 years 1 week ago #187053 by phillc54
Replied by phillc54 on topic Valid Arc Lost 2
What mode do have set for PlasmaC in the ini file?
6 years 1 week ago #187055 by benbenben
Mode 2
6 years 1 week ago #187056 by phillc54
Then your external THC is probably telling PlasmaC that the arc is lost.
