PlasmaC doesn't seem to use M190 material call in Gcode
26 Sep 2020 11:25 #183835 by rodw
I don't use the F360 PP but when I read the post processor file, There are comments to say the small hole section has been reverted to normal
It appears that it is only used for centerpunching. I can't see from the code that it will ever use a small hole for anything other than a centrepunch.My guess is if you have not set up your environment correctly, you may get some problems.
26 Sep 2020 11:38 #183838 by phillc54
If you look at the gcode produced, it reduces feed rate to 60%, does an arc leadin, does the hole then does a torch off overcut for 4mm then resets the feed rate to 100% and re-enables the torch.
29 Sep 2020 02:29 #184235 by phillc54
I pushed an update so now the G-Code filter changes the material if it sees a material change so that should fix the radius error.
03 Oct 2020 03:28 #184659 by turbodude
Awesome, thanks Phil.
Time to create page: 0.598 seconds
