Plasmac probe
- fupeama
- Thank you received: 14
01 Oct 2020 07:55 #184458
by fupeama
Plasmac probe was created by fupeama
I'm trying to set up probe proces on machine but without success.
I have pneumatic cylinder witch probe contact and I need...
Move probe (nozzle) to X Y location.
eject probe with pneumatic cylinder to probe position.
go down Z axis until probe triggers.
Slowly raise Z axis to find top of material.
pull up pneumatic cylinder (probe contact).
wait for probe contact is up.
set pierce height (go down because probe contact is longer than nozzle)
cut
I need somethink like probe-out for detecting request for probe and probe-finished to tell mashine that can start move.
Is it possible to do with plasmac?
Thanks Martin
cut
Thanks Martin
- phillc54
- Thank you received: 2100
01 Oct 2020 08:02 #184460
by phillc54
Replied by phillc54 on topic Plasmac probe
There is a HAL pin named plasmac.state-out which changes value at the beginning of each state. The values are:
Warning: Spoiler!
0 IDLE
1 PROBE_HEIGHT
2 PROBE_DOWN
3 PROBE_UP
4 ZERO_HEIGHT
5 PIERCE_HEIGHT
6 TORCH_ON
7 ARC_OK
8 PIERCE_DELAY
9 PUDDLE_JUMP
10 CUT_HEIGHT
11 CUT
12 PAUSE_AT_END
13 SAFE_HEIGHT
14 MAX_HEIGHT
15 FINISH
16 TORCHPULSE
17 PAUSED_MOTION
18 OHMIC_TEST
19 PROBE_TEST
20 SCRIBING
21 CONSUMABLE_CHANGE_ON
22 CONSUMABLE_CHANGE_OFF
23 CUT_RECOVERY_ON
24 CUT_RECOVERY_OFF
25 DEBUGPlease Log in or Create an account to join the conversation.
- fupeama
01 Oct 2020 08:20 #184461
by fupeama
Replied by fupeama on topic Plasmac probe
Thanks Phill, thats perfect.
M
M
Time to create page: 0.120 seconds
