PlasmaC laser offset (SOLVED)
- Clive S
- Thank you received: 486
25 Oct 2020 15:30 - 26 Oct 2020 12:05 #187199
by Clive S
PlasmaC laser offset (SOLVED) was created by Clive S
I have done an update to the latest version 0.180. from about 2 months ago.
The laser offset seems to work in a different manor in that when you move to a position then use the offset button it moves to the correct place but does not show on screen but when cutting the part it cuts ok bet does not follow the onscreen outline.
If you then press the normal X touch off on the gui the image on screen moves to the correct position.
Has the code changed?
I use this:
BUTTON_1_NAME = Laser\Offset
#BUTTON_1_CODE = G54 G0 X-47.5 Y21.296
BUTTON_1_CODE = G10 L20 P1 X0 Y0 \ G54 G1 X -47.5 Y 21.296 F2000 \ G10 L20 P1 X0 Y0
I use this:
Last edit: 26 Oct 2020 12:05 by Clive S.
- phillc54
- Thank you received: 2100
25 Oct 2020 23:56 #187258
by phillc54
to the end of your existing code and it will refresh the preview screen.
See the "Touch Off X & Y" section here:
linuxcnc.org/docs/2.8/html/plasma/plasma...de.html#_button_code.
Replied by phillc54 on topic PlasmaC laser offset
That code is run by LinuxCNC itself, not PlasmaC. I don't think the preview can be refreshed in Gmoccapy but in Axis there is a new refresh pin available so you could add:I have done an update to the latest version 0.180. from about 2 months ago.
I use this:
\ %halcmd setp axisui.refresh 1See the "Touch Off X & Y" section here:
The following user(s) said Thank You: Clive S, snowgoer540
- snowgoer540
- Thank you received: 907
26 Oct 2020 00:15 #187260
by snowgoer540
Replied by snowgoer540 on topic PlasmaC laser offset
Came here to write essentially what Phill did earlier, got distracted because someone used my credit card to order themselves dinner on Uber Eats... so I got bogged down disputing charges, and then updating all the autopay stuff with the new credit card number (which conveniently they issue instantly).
- phillc54
26 Oct 2020 01:11 #187262
by phillc54
Mmmm, those lamb cutlets were delicious.Came here to write essentially what Phill did earlier, got distracted because someone used my credit card to order themselves dinner on Uber Eats... so I got bogged down disputing charges, and then updating all the autopay stuff with the new credit card number (which conveniently they issue instantly).
- snowgoer540
26 Oct 2020 01:46 #187265
by snowgoer540
heard it pairs well with a good bourbon
- Clive S
26 Oct 2020 12:07 - 26 Oct 2020 22:40 #187301
by Clive S
Replied by Clive S on topic PlasmaC laser offset (SOLVED)
Thanks Phill. That did the trick
Edit: Thanks to snowgoer540 for the help as well.
Last edit: 26 Oct 2020 22:40 by Clive S.
The following user(s) said Thank You: phillc54, snowgoer540
- phillc54
26 Oct 2020 22:30 #187348
by phillc54
Replied by phillc54 on topic PlasmaC laser offset (SOLVED)
No worries Clive. And thanks to snowgoer540 for contributing this HAL pin.Thanks Phill. That did the trick
- Thank you received: 4154
27 Oct 2020 08:00 #187388
Replied by rodw on topic PlasmaC laser offset (SOLVED)
If you are using Gmocappy, you can use the provided Macro buttons. I suspect that will sort out the screen refresh as I've never noticed the problem Greg mentioned doing it that way.
