Losing Arc On Holes
- little_sparky
- Thank you received: 17
06 Nov 2020 11:34 #188491
by little_sparky
Losing Arc On Holes was created by little_sparky
Hi All,
Does anyone have trouble losing an arc when cutting holes?
I’ve got to a point now where no matter what lead in or lead out I use, I can’t cut any more than 2 holes in a row without losing a valid arc.
Any help is appreciated
(Ps. I thought I saw a thread on something similar to this once but can’t find it)
- Thank you received: 7490
06 Nov 2020 13:04 #188496
Replied by tommylight on topic Losing Arc On Holes
Yes it's been happening a lot, and yes it is already fixed but the buildbot is for some resaon not updating the builds, although i am not sure Phill pushed the fix yet.
I did test it on two machines and it works properly set at 0.3 sec delay.
- little_sparky
07 Nov 2020 06:42 #188574
by little_sparky
Replied by little_sparky on topic Losing Arc On Holes
Yeah I definitely need to update then, havnt updated for a few months.
Also, anyone who comes across this thread for future notice, I set the lead-in to perpendicular instead of arc and have had much better results, only about 8% of holes give an error now.
- phillc54
- Thank you received: 2100
07 Nov 2020 10:35 #188584
by phillc54
Replied by phillc54 on topic Losing Arc On Holes
I will push that some time tomorrow.Yes it's been happening a lot, and yes it is already fixed but the buildbot is for some resaon not updating the builds, although i am not sure Phill pushed the fix yet.
The following user(s) said Thank You: tommylight, little_sparky
Time to create page: 0.087 seconds
