Mesa 7i96 with THCAD300 HAL, INI files and backup
- justas123
06 Nov 2020 19:28 #188531
by justas123
Mesa 7i96 with THCAD300 HAL, INI files and backup was created by justas123
Hello,
Maybe someone can share backup files of install (ini and hal also others). I can't find why M3 $0 S1 command doesn't work all configurations seems to be ok.
One more interesting detail that I can turn torch by using "Torch pulse", also Probe test is not active in GMOCCopy version 3.0.9.1.
- Thank you received: 7501
06 Nov 2020 19:38 #188532
Replied by tommylight on topic Mesa 7i96 with THCAD300 HAL, INI files and backup
You are not helping yourself by posting all over the place, you were asked to provide your hal and ini files in the other topic you asked about it, so compress the config folder and upload it here OR there so we can have a look.
And use the search, there are plenty of configs using PlasmaC, a Mesa 7i96 and a THCAD :
www.google.com/search?source=hp&ei=DaalX...FhALoQ4dUDCAY&uact=5
- justas123
06 Nov 2020 19:55 #188535
by justas123
Replied by justas123 on topic Mesa 7i96 with THCAD300 HAL, INI files and backup
I have solved it just now I am new with Linux, before I was using Mach3 but had a lot of problem with not stable system.
And I have noticed that before any action all you need is just make home for all axis
, super I will move foward I will upload video then it will work. My machine size 3x6m
06 Nov 2020 20:39 #188539
And yes, most industrial or DIY machines using two motors fro one axis will require homing before doing anything with it.
That is a big machine !My machine size 3x6m
Time to create page: 0.065 seconds
