Breakaway error
5 years 11 months ago #188817 by tommylight
Replied by tommylight on topic Breakaway error
No worries, it just makes it really hard for us to follow and keep track of what we already did answer and what not.
First check the grounding, that is the main thing for proper operation of a plasma cutter, then use shielded cable and attach the shielding to ONLY the electronics side or the control box, always do grounding from a single point namely from the main power cord and go from there to other parts of the machine, use a shield for each cable and attach all of them to that single point in the box. No daisy chaining.
5 years 11 months ago #188825 by KaleD
Replied by KaleD on topic Breakaway error
I wired it normally closed. It works this way. I think this helps with the EMI noise a little too.
5 years 11 months ago #188828 by snowgoer540
Replied by snowgoer540 on topic Breakaway error
Kale Dobrohoczki wrote: I wired it normally closed. It works this way. I think this helps with the EMI noise a little too.
Good, glad to hear! And it’s a wee bit safer too!
Time to create page: 0.278 seconds
