Plasmac updated to the wrong disto
- Foldaround
- Thank you received: 7
05 Dec 2020 01:48 #191092
by Foldaround
Plasmac updated to the wrong disto was created by Foldaround
Late last night while installing my new reed switch arc ok I decided it was a great time to upgrade linuxcnc. I used the offline install method with buildbot.linuxcnc.org and made a wonderful error installing the "scratch-rtpreempt" reading it as "stretch-rtpreempt". Not realizing my mistake until the next day I processed to chase errors until I could finally connect with my CNC machine. Now my issue is when I did this it updated my current working .hal .ini files (I thought I had a recent backup but it wasn't as recent as I would have hoped...yikes).
So I uninstalled that version and installed the correct version 2.8.1 for my machine but when I run the plasmac configurator and create a new file using my current .ini .hal files as the base it still has alot of what seems to be development stuff going on. I have double tabs for the config, statistics, extras in axis which I'm pretty sure isn't normal.
So my humble question is how to I revert back?
Im pretty sure the answer is to run pncconf again and start the build all over from scratch but that process is a pain as Im now running THCAD 10 driven THC, THCAD 5 driven ohmic sensor, and my new reed switch arc ok.
Feel free to tell me to stop dragging my feet and rebuild, I just thought I would reach out and see if easy street was an option
- phillc54
- Thank you received: 2100
05 Dec 2020 01:55 #191094
by phillc54
Replied by phillc54 on topic Plasmac updated to the wrong disto
If they are your only issues, edit the ini file and remove duplicate gladevcp entries in the [DISPLAY] section.
- Foldaround
05 Dec 2020 02:08 #191097
by Foldaround
Replied by Foldaround on topic Plasmac updated to the wrong disto
Fixed!
Phill let me know where to send the beer
- phillc54
05 Dec 2020 02:12 #191098
by phillc54
Haha, funny you should say that, I only have two left in the Esky and we haven't started lunch yet.
Fixed!
Time to create page: 0.123 seconds
