Change to the post in the stickied section of the PlasmaC thread on this forum.Talon2006 wrote: I am using plasma 2.8, and just updated to the latest version (I forget the number). I am also using sheetcam with Rodw's post processor. After the update I have a few questions. Not sure if updating I got a few bugs in my system. I did a quick search, but have not found the information I needed yet. If I do find it I will update my own thread.
Hard to say without seeing your gcode but I suspect it’s with relation to above. I’d guess the M3 is not called out correctly but this is just a guess without any code to look at.First question, probing. I hit probe test, it goes down at full rapid, then it slows down to probing speed for the last inch as that is how I have it configured. After that I go to start my cut file, and it probes full speed all the way down to the plate. Is it suppose to do this? Why can't I get it to slow down the last inch, or better yet the last 1/2- 1/4 inch? I don't like it slamming down into the metal at 150-200 ipm. If I could get it to slow down I could have the Z move much faster.
Second, when I am cutting, if I change my cut settings in the tool set, will it automatically update as it is cutting? Say if I want to speed up or slow down cut speed during a program or change my THC voltage. Would it implement those changes in the next move of the file, in real time or would I have to restart the program. My understanding is that plasma will ignore the settings in the g code from sheet cam, and use the tool setting list on plasmac (which is also the sale tool/settings I have in sheetcam.)
Talon2006 wrote: Thank you!! Sorry for not posting the version and g code. I am at work and just thinking about things I want to work on. I can post it later.
First step is going to be updating the post processor to the stickered one.
That does seems odd, there is only one probe routine in plasmac and it is used for both probe test and probe before cut so there "should" be no difference in behaviour. Can you post the backup of you config folder.Talon2006 wrote: First question, probing. I hit probe test, it goes down at full rapid, then it slows down to probing speed for the last inch as that is how I have it configured. After that I go to start my cut file, and it probes full speed all the way down to the plate. Is it suppose to do this? Why can't I get it to slow down the last inch, or better yet the last 1/2- 1/4 inch? I don't like it slamming down into the metal at 150-200 ipm. If I could get it to slow down I could have the Z move much faster.
Cut speed cannot be changed on the fly. Cut speed is controlled by gcode, so if you change the speed in the parameters then it will not change in a running program until the next F word is encountered. You can use feed override to achieve this.Second, when I am cutting, if I change my cut settings in the tool set, will it automatically update as it is cutting? Say if I want to speed up or slow down cut speed during a program or change my THC voltage. Would it implement those changes in the next move of the file, in real time or would I have to restart the program. My understanding is that plasma will ignore the settings in the g code from sheet cam, and use the tool setting list on plasmac (which is also the sale tool/settings I have in sheetcam.)
