Rotary cutting square tube with PlasmaC?
- Thank you received: 7485
10 Jan 2021 20:45 #194776
Replied by tommylight on topic Rotary cutting square tube with PlasmaC?
Round tube.
- robertspark
- Thank you received: 216
10 Jan 2021 21:09 - 10 Jan 2021 21:10 #194779
by robertspark
Replied by robertspark on topic Rotary cutting square tube with PlasmaC?
for round tube I just use one of these with a bracket to hang it underneath / supported to my table + allow me to square it.
i.ebayimg.com/images/g/AwgAAOSwUY9dPzvk/s-l1600.jpg
with a bit of an uprated stepper motor (nema 23, 4.2A, 3.1Nm)
www.cnc4you.co.uk/Stepper-Motor/Nema23-3...Nm-60BYGH301B-Nema23
I don't do a lot of tube, but it works fine for my hobbist needs (beats an angle grinder + flapdisc / file....)
Last edit: 10 Jan 2021 21:10 by robertspark.
- Thank you received: 4149
10 Jan 2021 21:13 #194780
Replied by rodw on topic Rotary cutting square tube with PlasmaC?
So anyway, back to the original question. I think to use the Sheetcam rotary plugin for square tube, you probably would be best not using Plasmac so you have gcode control of the Z axis. start the torch with the spindle.0.on signal, and do the probing in Gcode using a touch off routine. BigJohn has an example on his web site gnipsel.com if you can't work it out.
You won't need a THC or any fancy features so a standard axis config would do the job for you.
10 Jan 2021 21:17 #194781
Robert is that a 4 jaw self centring chuck? They would be perfect for square tube.
- robertspark
10 Jan 2021 23:23 - 10 Jan 2021 23:24 #194808
by robertspark
yes that is why I got it / went with the 4 jaw self-centring. (also better with thinner wall tube)
I've not tried it with square tube.... but it was a nice to have / just in case feature.
Last edit: 10 Jan 2021 23:24 by robertspark.
The following user(s) said Thank You: rodw, razplaz
- phillc54
- Thank you received: 2100
10 Jan 2021 23:26 #194809
by phillc54
It would be easy enough to add an option in the gcode parser for a magic comment to not remove Z axis motion commands.
Replied by phillc54 on topic Rotary cutting square tube with PlasmaC?
10 Jan 2021 23:31 #194810
That would be cool. But some way the Sheetcam post could set that without changing the post processor would be even better. I don't know the Sheetcam rotary. does it have a different post?
I wonder if a cutting rule could be used to insert the comment?
- robertspark
11 Jan 2021 00:32 #194826
by robertspark
Just looking at sheetcam now there actually is a LinuxCNC Plasma Rotary post processor listed:
--*** Set these values up to suit your machine ***
--scriber axis.
--scriberAxis = "B"
scriberAxis = "Z"
--If this value is set to true then use G28 (home) for the Z reference
--Set it to false for G31 probe
refHome = true
--rotary axis. Normally this would be "A"
rotaryAxis = "A"
--Number of units for one full revolution of the rotary axis
--Note: In Mach3 the axis should be defined as linear, not rotary!
unitsPerRev=360
-- Rapids will move the shortest distance to the next cut but may cause machines with limited rotation
-- to 'wind up'. Set this to 0 to disable optimisation.
--defaults to 1 if not defined
optimiseRapids = 1
--*** End of settings ***
function OnAbout(event)
ctrl = event:GetTextCtrl()
ctrl:AppendText("Post for rotary-plasma plugin LinuxCNC plasma\n")
ctrl:AppendText("\n")
ctrl:AppendText("Modal G-codes and coordinates\n")
ctrl:AppendText("Comments enclosed with ( and )\n")
ctrl:AppendText("Incremental IJ\n")
end
-- revision 3/2/07
-- Removed final safety move. This is now done in SheetCam
-- revision 7/10/04
-- Added new arc handling
-- Created 30/3/2005
-- based on Mach2.post
function OnInit()
post.SetCommentChars ("()", "[]") --make sure ( and ) characters do not appear in system text
post.Text (" (Filename: ", fileName, ")\n")
post.Text (" (Post processor: ", postName, ")\n")
post.Text (" (Date: ", date, ")\n")
if(scale == metric) then
post.Text (" G21 (Units: Metric)\n") --metric mode
else
post.Text (" G20 (Units: Inches)\n") --inch mode
end
post.Text (" G40 G90\n F1 S1\n")
bigArcs = 1 --stitch arc segments together
minArcSize = 0.05 --arcs smaller than this are converted to moves
end
function OnNewLine()
post.Text ("N")
post.Number (lineNumber, "0000")
lineNumber = lineNumber + 10
end
function OnFinish()
post.Text (" M05 M30\n")
end
function OnRapid()
post.ModalText (" G00")
post.ModalNumber (" X", endX * scale, "0.0000")
post.ModalNumber (" Y", endY * scale, "0.0000")
post.ModalNumber (" Z", (endZ + toolOffset) * scale, "0.0000")
post.ModalNumber (" " .. rotaryAxis, endA, "0.0000")
post.Eol()
end
function OnMove()
post.ModalText (" G01")
post.ModalNumber (" F", feedRate * scale, "0.###")
post.Eol()
end
function OnArc()
local radius = math.hypot(currentX - arcCentreX, currentY - arcCentreY)
dist = dist + radius * math.abs(arcAngle)
if(arcAngle <0) then
post.ModalText (" G03")
else
post.ModalText (" G02")
end
if(offZ) then
post.ModalNumber (" " .. currentZAxis, (endZ + offZ) * scale, "0.0000")
end
post.Text (" I")
post.Number ((arcCentreX - currentX) * scale, "0.0000")
post.Text (" J")
post.Number ((arcCentreY - currentY) * scale, "0.0000")
post.ModalNumber (" F", feedRate * scale, "0.0###")
post.Eol()
end
function OnPenDown()
local matZ = sc.QueryDll(qryCHKEND, endY, dllId)
post.NonModalNumber(" o<touchoff> call [" ,(pierceHeight + matZ) * scale ,"0.000" )
post.Text ("] ")
post.NonModalNumber("[", pierceDelay * scale, "0.##")
post.Text ("] ")
post.NonModalNumber("[", cutHeight * scale, "0.##")
post.Text ("] (Touchoff and start cutting)\n")
post.NonModalNumber (" F", feedRate * scale, "0.###")
post.Eol()
end
function OnPenUp()
post.Text (" M05\n")
if (endDelay > 0) then
post.Text (" G04 P")
post.Number (endDelay,"0.###")
post.Eol()
end
end
function OnNewOperation()
post.Text (" (Operation: ", operationName, ")\n")
end
function OnComment()
post.Text(" (",commentText,")\n")
end
function OnNewPart()
post.Text(" (Part: ",partName,")\n");
end
function OnDrill()
OnRapid()
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
end
function OnFinish()
post.Text ("G92.1 (Cancel offsets and set to zero)\n")
post.Text ("G0 Z0\n")
post.Text ("M2\n")
post.Text ("%\n")
end
--Set this to the number of units for one full revolution of the A axis. For example 360 = 360 degrees.
unitsPerRev=360
package.path = sc.Globals:Get().thisDir .. "/plugins/RotaryPlasma/?.lua"
require("rotaryhelper")
--change this to 1 if your machine is a robot
--defaults to 0
isRobot = 0
--maximum error when converting arcs to multiple line segments.
--Smaller numbers give better resolution but larger code size.
--defaults to 0.1
arcResolution = 0.1
--defaults to 1
optimiseRapids = 0
--Set this to false if your code does not do a reference cycle
ignorePierceHeightMove = true
function OnArc()
post.ArcAsMoves(0.1)
end Please Log in or Create an account to join the conversation.
11 Jan 2021 01:00 #194835
If you look at onPenDown it requires a touchoff routine in a seperate gcode file. You can grab BigJohn's from here:
gnipsel.com/shop/plasma/plasma.xhtml
This will get you going but you can improve on this by probing back away form the material (check the gcode docs).
- phillc54
11 Jan 2021 11:11 #194878
by phillc54
I put a magic comment in the QtPlasmaC gcode parser, so if anyone is game they can give it a try, it is called #<keep-z-motion>
#<keep-z-motion> = 1, you can make z axis moves and qtplasmac will NOT make the initial Z move
#<keep-z-motion> = anything else, it behaves as existing
if it is not in the gcode file it means it behaves as existing
The following user(s) said Thank You: tommylight, rodw, snowgoer540, razplaz
Time to create page: 0.533 seconds
