Getting an error when I launch my Plasmac configuration
13 Jan 2021 03:47 #195167 by Nick7251
Can anybody help me make sense of what my error my be from this report?
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0
Machine configuration directory is '/home/linuxshop/linuxcnc/configs/shop_plasma'
Machine configuration file is 'shop_plasma.ini'
INIFILE=/home/linuxshop/linuxcnc/configs/shop_plasma/shop_plasma.ini
VERSION=1.1
PARAMETER_FILE=imperial_parameters.txt
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYYZ
KINEMATICS=trivkins coordinates=XYYZ kinstype=BOTH
Starting LinuxCNC...
twopass:invoked with <> options
twopass:found ./shop_plasma.hal
twopass:found ././plasmac/plasmac.tcl
twopass:found ./shop_plasma_connections.hal
twopass: Error in file ./shop_plasma_connections.hal:
    Pin 'hm2_7i96.0.gpio.010.in' was already linked to signal 'din-00'
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:16:02:a1
hm2_eth: discovered 7I96
hm2/hm2_7i96.0: Smart Serial Firmware Version 43
hm2/hm2_7i96.0: 51 I/O Pins used:
hm2/hm2_7i96.0:     IO Pin 000 (TB3-01): IOPort
hm2/hm2_7i96.0:     IO Pin 001 (TB3-02): IOPort
hm2/hm2_7i96.0:     IO Pin 002 (TB3-03): IOPort
hm2/hm2_7i96.0:     IO Pin 003 (TB3-04): IOPort
hm2/hm2_7i96.0:     IO Pin 004 (TB3-05): IOPort
hm2/hm2_7i96.0:     IO Pin 005 (TB3-06): IOPort
hm2/hm2_7i96.0:     IO Pin 006 (TB3-07): IOPort
hm2/hm2_7i96.0:     IO Pin 007 (TB3-08): IOPort
hm2/hm2_7i96.0:     IO Pin 008 (TB3-09): IOPort
hm2/hm2_7i96.0:     IO Pin 009 (TB3-10): IOPort
hm2/hm2_7i96.0:     IO Pin 010 (TB3-11): IOPort
hm2/hm2_7i96.0:     IO Pin 011 (TB3-13/TB3-14): SSR #0, pin Out-00 (Output)
hm2/hm2_7i96.0:     IO Pin 012 (TB3-15/TB3-16): SSR #0, pin Out-01 (Output)
hm2/hm2_7i96.0:     IO Pin 013 (TB3-17/TB3-18): SSR #0, pin Out-02 (Output)
hm2/hm2_7i96.0:     IO Pin 014 (TB3-19/TB3-20): SSR #0, pin Out-03 (Output)
hm2/hm2_7i96.0:     IO Pin 015 (TB3-21/TB3-22): SSR #0, pin Out-04 (Output)
hm2/hm2_7i96.0:     IO Pin 016 (TB3-23/TB3-24): SSR #0, pin Out-05 (Output)
hm2/hm2_7i96.0:     IO Pin 017 (TB1-02/TB1-03): StepGen #0, pin Step (Output)
hm2/hm2_7i96.0:     IO Pin 018 (TB1-04/TB1-05): StepGen #0, pin Direction (Output)
hm2/hm2_7i96.0:     IO Pin 019 (TB1-08/TB1-09): StepGen #1, pin Step (Output)
hm2/hm2_7i96.0:     IO Pin 020 (TB1-10/TB1-11): StepGen #1, pin Direction (Output)
hm2/hm2_7i96.0:     IO Pin 021 (TB1-14/TB1-15): StepGen #2, pin Step (Output)
hm2/hm2_7i96.0:     IO Pin 022 (TB1-16/TB1-17): StepGen #2, pin Direction (Output)
hm2/hm2_7i96.0:     IO Pin 023 (TB1-20/TB1-21): StepGen #3, pin Step (Output)
hm2/hm2_7i96.0:     IO Pin 024 (TB1-22-TB1-23): StepGen #3, pin Direction (Output)
hm2/hm2_7i96.0:     IO Pin 025 (TB2-01/TB2-03): StepGen #4, pin Step (Output)
hm2/hm2_7i96.0:     IO Pin 026 (TB2-04/TB2-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i96.0:     IO Pin 027 (TB2-07/TB2-08): Encoder #0, pin A (Input)
hm2/hm2_7i96.0:     IO Pin 028 (TB2-10/TB2-11): Encoder #0, pin B (Input)
hm2/hm2_7i96.0:     IO Pin 029 (TB2-13/TB2-14): Encoder #0, pin Index (Input)
hm2/hm2_7i96.0:     IO Pin 030 (TB2-16/TB2-17): IOPort
hm2/hm2_7i96.0:     IO Pin 031 (TB2-18/TB2-19): IOPort
hm2/hm2_7i96.0:     IO Pin 032 (internal): IOPort
hm2/hm2_7i96.0:     IO Pin 033 (internal): SSR #0, pin AC Ref (internal) (Output)
hm2/hm2_7i96.0:     IO Pin 034 (P1-01): IOPort
hm2/hm2_7i96.0:     IO Pin 035 (P1-02): IOPort
hm2/hm2_7i96.0:     IO Pin 036 (P1-03): IOPort
hm2/hm2_7i96.0:     IO Pin 037 (P1-04): IOPort
hm2/hm2_7i96.0:     IO Pin 038 (P1-05): IOPort
hm2/hm2_7i96.0:     IO Pin 039 (P1-06): IOPort
hm2/hm2_7i96.0:     IO Pin 040 (P1-07): IOPort
hm2/hm2_7i96.0:     IO Pin 041 (P1-08): IOPort
hm2/hm2_7i96.0:     IO Pin 042 (P1-09): IOPort
hm2/hm2_7i96.0:     IO Pin 043 (P1-11): IOPort
hm2/hm2_7i96.0:     IO Pin 044 (P1-13): IOPort
hm2/hm2_7i96.0:     IO Pin 045 (P1-15): IOPort
hm2/hm2_7i96.0:     IO Pin 046 (P1-17): IOPort
hm2/hm2_7i96.0:     IO Pin 047 (P1-19): IOPort
hm2/hm2_7i96.0:     IO Pin 048 (P1-21): IOPort
hm2/hm2_7i96.0:     IO Pin 049 (P1-23): IOPort
hm2/hm2_7i96.0:     IO Pin 050 (P1-25): IOPort
hm2/hm2_7i96.0: registered
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
7793
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file:    /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
     http://pastebin.com
in order to provide information about the linuxcnc
system and configuration.
                Date: Tue Jan 12 20:42:06 MST 2021
            UTC Date: Wed Jan 13 03:42:06 UTC 2021
        this program: /usr/bin/linuxcnc_info
              uptime: 20:42:06 up 8:54, 1 user, load average: 0.54, 0.50, 0.32
     lsb_release -sa: LinuxMint Linux Mint 19.3 Tricia 19.3 tricia
      which linuxcnc: /usr/bin/linuxcnc
                 pwd: /home/linuxshop/linuxcnc/configs/shop_plasma
                USER: linuxshop
             LOGNAME: linuxshop
                HOME: /home/linuxshop
              EDITOR:
              VISUAL:
            LANGUAGE: en_US
                TERM: dumb
           COLORTERM:
             DISPLAY: :0.0
             DESKTOP: xfce
        display size: 1280x1024 pixels (338x270 millimeters)
                PATH: /usr/bin:/home/linuxshop/linuxcnc/configs/shop_plasma/bin:/usr/bin:/home/linuxshop/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
uname items:
         nodename -n: linuxshop
      kernel-name -s: Linux
      kernel-vers -v: #1 SMP PREEMPT RT Mon Sep 14 12:23:06 AEST 2020
          machine -m: x86_64
        processor -p: x86_64
         platform -i: x86_64
      oper system -o: GNU/Linux
/proc items:
             cmdline: efi=runtime BOOT_IMAGE=/boot/vmlinuz-4.19.106-rt46-lcnc root=UUID=e28d6d46-05e6-4310-a87e-cadff1e539e0 ro quiet splash vt.handoff=1
          model name: Intel(R) Core(TM) i7-7567U CPU @ 3.50GHz
               cores: 2
             cpu MHz: 3900.151
             parport:
              serial:
Versions:
                 gcc: gcc (Ubuntu 7.5.0-3ubuntu1~18.04) 7.5.0
              python: Python 2.7.17
                 git: git version 2.17.1
          git commit: NA
                 tcl: 8.6
                  tk: 8.6
               glade: not_in_PATH
          glade-gtk2: not_in_PATH
linuxcnc_var all:
     LINUXCNCVERSION: 2.8.0
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
            REALTIME: /etc/init.d/realtime
                 RTS: uspace
          HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                Version               Architecture Description
un  linuxcnc            <none>                <none>       (no description available)
un  linuxcnc-dev        <none>                <none>       (no description available)
un  linuxcnc-doc        <none>                <none>       (no description available)
ii  linuxcnc-doc-en     1:2.8.0.96.g589db060d all          motion controller for CNC machines and robots (English documentation)
un  linuxcnc-sim        <none>                <none>       (no description available)
un  linuxcnc-sim-dev    <none>                <none>       (no description available)
ii  linuxcnc-uspace     1:2.8.0.96.g589db060d amd64        motion controller for CNC machines and robots
ii  linuxcnc-uspace-dev 1:2.8.0.96.g589db060d amd64        PC based motion controller for real-time Linux
13 Jan 2021 04:14 #195168 by Nick7251
I think I figured it out. I assigned my input pins in the pncconf setup, so the plasmac setup read those pins as already taken.
Time to create page: 0.080 seconds
