PlasmaC to work without probing
- Pro_El
- Thank you received: 3
14 Jan 2021 15:58 #195327
by Pro_El
PlasmaC to work without probing was created by Pro_El
Hello to everyone
I am building new plasma machine and i will not going to use THC or probes. For z axis i will have pneumatic cylinder for up and down and Floating head.
I need to now if i can configure PlasmaC or QtPlasmaC to work on this way and how. I need to disable probing before pricing and just need digital output bit for Z axis down. I am working on Buster with LCNC 2.9.
I try to find answer to this and install PlasmaC but i cannot turn off this probing future before pricing.
Thanks to all
Thanks to all
- Thank you received: 7501
14 Jan 2021 16:00 #195328
Replied by tommylight on topic PlasmaC to work without probing
Will you be using THC ?
The following user(s) said Thank You: Pro_El
- Pro_El
14 Jan 2021 16:13 #195330
by Pro_El
Replied by Pro_El on topic PlasmaC to work without probing
No. I will not going to use THC. i want just to have floating head and pneumatic for up and down Z axis.
14 Jan 2021 16:18 #195331
No need for PlasmaC then, a normal config will work just fine, so you can use any of the included GUI's.
- Pro_El
14 Jan 2021 16:21 - 14 Jan 2021 16:22 #195332
by Pro_El
Ok, but how can i rename Spindle button to Torch and i like stuff like statistic for number of pricing and time....
Last edit: 14 Jan 2021 16:22 by Pro_El.
14 Jan 2021 16:41 #195334
A simple way would be to tie the torch on to coolant or mist and use the M7/M8 to turn them on instead of M3, and use M9 to turn them off instead of M5.
Ok, for that you do need PlasmaC, so wait for Phill to chime in on how to disable probing.Ok, but how can i rename Spindle button to Torch and i like stuff like statistic for number of pricing and time....
- phillc54
- Thank you received: 2100
15 Jan 2021 05:49 - 15 Jan 2021 05:55 #195403
by phillc54
Replied by phillc54 on topic PlasmaC to work without probing
If you wanted to use the PlasmaC configuration for this you would need to rewrite quite a lot of the plasmac.comp file plus maybe even some of the GUI code. I don't think it would be a trivial task. It would probably be easier to write your own QtVCP or GladeVCP panel for statistics.
Edit: If you used GladeVCP you could utilise the existing statistics panel and some of the existing code. Most hal connections wuld need to be changed to suit any new code.
Statistics panel
Statistics python code
Statistics hal connections
Statistics panel
Last edit: 15 Jan 2021 05:55 by phillc54.
- Pro_El
15 Jan 2021 22:11 #195491
by Pro_El
Thanks Phillip
I have little experience with QTVCP and try to make some simple window that will work for me.
Time to create page: 0.076 seconds
