toolsets
- wade956
- Thank you received: 3
17 Jan 2021 19:15 #195696
by wade956
toolsets was created by wade956
Hello, I need help with toolsets. I've added a toolset from the sticky to sheet cam and it appears to work. But when I add the same tool set to Plasmac they do not come across the same - almost everything is set to 1.0000. Thanks.
- phillc54
- Thank you received: 2100
17 Jan 2021 22:10 #195712
by phillc54
Replied by phillc54 on topic toolsets
Can you post the plasmac materials file
- wade956
17 Jan 2021 22:50 #195716
by wade956
Replied by wade956 on topic toolsets
See attached, torch all of the numbers seem off? torch height etc.
- phillc54
17 Jan 2021 23:43 #195721
by phillc54
Can you post the sheetcom file?
- wade956
17 Jan 2021 23:52 #195725
by wade956
attached
- phillc54
18 Jan 2021 01:04 #195734
by phillc54
The tool file and the material file you posted match up with each other except for material #7.
The images you show do not correspond with the material file you posted.
When you saved this material file did you give it the correct name and did you put it in your config folder.
The file name should be <machine_name>_material.cfg
- wade956
18 Jan 2021 01:44 #195738
by wade956
thanks for looking, yes saved in the same folder as the machine I use. I did put other toolsets in to see if they would work but the result is always the same when i lookin plasmac..
- phillc54
18 Jan 2021 01:47 #195739
by phillc54
Can you post a zip of your config folder.
The following user(s) said Thank You: wade956
- wade956
18 Jan 2021 02:07 #195742
by wade956
Attached
- phillc54
18 Jan 2021 02:32 #195743
by phillc54
I think you need to run the materialverter again but you need to select imperial output.
Time to create page: 0.209 seconds
