Pausing at Nodes
- CBEAR
- Thank you received: 46
- phillc54
- Thank you received: 2100
G64 P0.01 Q0.001 (tracking tolerances: 0.01")To:
G64 P0.01 (tracking tolerances: 0.01")Please Log in or Create an account to join the conversation.
- CBEAR
- phillc54
if scale == metric then
post.Text (' G64 P0.254 Q0.025 (tracking tolerances: 0.254mm)\n')
else
post.Text (' G64 P0.01 Q0.001 (tracking tolerances: 0.01")\n')
endPlease Log in or Create an account to join the conversation.
- CBEAR
- CBEAR
Sure, it is in the current postprocessor at line 72, it looks like:
just change it so it looks the same.if scale == metric then post.Text (' G64 P0.254 Q0.025 (tracking tolerances: 0.254mm)\n') else post.Text (' G64 P0.01 Q0.001 (tracking tolerances: 0.01")\n') end
I have revision F if that makes a difference
- CBEAR
- snowgoer540
- Thank you received: 907
It seems to have been a sheetcam issue with import tolerances being too small!
Happy we finally got this figured out!!
To anyone following along, we changed this import setting in sheetcam:
Max detail reduction errorPer sheetcam manual:
Some drawings consist of a large number of very small line segments (especially polyline curves converted to DXF). This can slow down processing and produce very large g-code files. It can also slow down machining. SheetCam tries to reduce the number of lines when it loads the drawing. Removing lines introduces small errors and this value is the maximum allowable error. For Plasma cutting you can afford to have quite a large error (say .020"). The setup wizard adjusts this value to suit.
