Pausing at Nodes
5 years 8 months ago #197873 by CBEAR
Replied by CBEAR on topic Pausing at Nodes
It seems to have been a sheetcam issue with import tolerances being too small!
The following user(s) said Thank You: phillc54, snowgoer540
5 years 8 months ago #197874 by snowgoer540
Replied by snowgoer540 on topic Pausing at Nodes
CBEAR wrote: It seems to have been a sheetcam issue with import tolerances being too small!
Happy we finally got this figured out!!
To anyone following along, we changed this import setting in sheetcam:
Max detail reduction error
from the default of 0.0004" to 0.010"
Per sheetcam manual:
Some drawings consist of a large number of very small line segments (especially polyline curves converted to DXF). This can slow down processing and produce very large g-code files. It can also slow down machining. SheetCam tries to reduce the number of lines when it loads the drawing. Removing lines introduces small errors and this value is the maximum allowable error. For Plasma cutting you can afford to have quite a large error (say .020"). The setup wizard adjusts this value to suit.
Time to create page: 0.270 seconds
