- Thank you received: 58
rodw wrote:
rodw wrote: I decided to try using my Mesa 7i76e spindle relay while we are exploring this thread but I will post on another thread about that as I had some errors...
Actually I resolved my error and its possibly relevant so I will post here.
I changed my torch on relay to be the 7i76e spindle enable relay. Removed the plasma cutter wires from my relay and connected to TB4-5 and tb4-6. Once I powered up the 7i76e, the torch came on unexpectedly so I switched off the plasma cutter. Then started up in a more orderly fashion and got a startup error from the plasma cutter which is described in the manual
Active Low seemed interesting and I was aware these digital relays are polarised so I swapped the wires around on the 7i76e and it is working perfect.
So I wonder if problems some people have been having using digital relays is becasue they have the wrong polarity?
I'm going to leave it this way and see how it goes...
