Powermax 45xp lost arc delay (Solved)
- Thank you received: 4151
14 Feb 2021 06:16 #198779
Replied by rodw on topic Powermax 45xp lost arc delay
The pull down resistor goes from your arcOK input pin to field power ground. When the arcOK circuit is energised, additional current passes through the resistor to ground and the 7i96 is unaffected. The resistor should be around 90 Ohms and be > 6 W. To use off the shelf components, 3 x 270 ohm 5 W resistors in parallel will give 90 Ohm, 15W. Keep them in the air for cooling. I have ordered a 100 Ohm 35 W TO220 style resistor with an appropriate heat sink which dissipates about 6W. More on that later.
If you use a mechanical relay to trigger your torch, you should place a diode (IN4004, IN4007 et al) across the coil contacts of the relay so that the band on the diode points back to the output pin. The other wire on the relay coil goes to field power ground. In view of your original post, I would try in this order.
1. Extending the THC delay as discussed.
2. Adding the ArcOK pulldown
3. Use an external relay for torch on but based on PCW's feedback, that is not necessary so hopefully you do not get to this step.
The following user(s) said Thank You: Nick7251
- phillc54
- Thank you received: 2100
14 Feb 2021 07:05 #198780
by phillc54
Replied by phillc54 on topic Powermax 45xp lost arc delay
Well you could use a capacitor across the contacts and you wouldn't need to be concerned with power dissipaion.So for safe operation over a broad range of machines, I think > 100 mA is required. Then power dissipation is a concern.
- robertspark
- Thank you received: 216
14 Feb 2021 17:26 #198815
by robertspark
Replied by robertspark on topic Powermax 45xp lost arc delay
2 pence / 2 cents....
dry contacts (i.e. physical switch, relay or contactor) are used because electronic devices (SSR's, optocouplers or optoisolators) can and do normally have a leakage / quiescent current.
dry contacts have no leakage current, hence zero chance of being triggered in error or held in the on condition.
The problem is with high impedence circuits, and the impedence is not given by hypertherm in their datasheets just a requirement for "dry contact closure".....
diodes (and in part capacitors) are not required unless the switched circuit uses a coil / relay arrangement because the collapsing field can induce a reverse voltage which can kill electronic devices. It is HIGHLY unlikey that you wlll need to use a diode as the switched circuit is highly unlikey to be a relay..... because it would not need a dry contact closure if it was as it would not be affected by (low) leakage currents through the relay coils (they would not have enough current to energise / hold the relay closed in my opinion)
I would suggest using a relay.... Do not use SSR's / optocouplers or optoisolators....
If it works for you.... great.... if not.... use a RELAY.....
I use very high speed (repeatable) reed relays for firing the torch signal. But a small (low current rated) relay will work just fine....
- Thank you received: 5330
14 Feb 2021 18:07 - 14 Feb 2021 18:21 #198820
Replied by PCW on topic Powermax 45xp lost arc delay
1. All switches have leakage current (it may be small but its always there)
2. Proper low power OPTO or SSR circuits do not have significant leakage current
3. If the Hypertherm start circuit is quite high impedance, a relay would be a bad idea due to the lack of contact wetting current so I would suggest _not_ using a relay for reliability reasons
BTW it would be valuable if someone with a Hypertherm measured the Plasma Start
circuit current with a DVM set to say a 200 mA range (they specify 18VDC open circuit voltage
but not the closed circuit current)
Last edit: 14 Feb 2021 18:21 by PCW.
- Thank you received: 7488
14 Feb 2021 21:27 #198847
I also have 3 other plasma sources, transformer type from 50 to 120A, two of them are outside, not in the shop !
Replied by tommylight on topic Powermax 45xp lost arc delay
I do have a small Hypertherm Max 43 or something, but it is manual only so no CPC port, i can measure that as soon as the temp goes up a bit as it is -10C here and 20cm of snow.BTW it would be valuable if someone with a Hypertherm measured the Plasma Start
- snowgoer540
- Thank you received: 907
14 Feb 2021 21:31 - 14 Feb 2021 21:32 #198848
by snowgoer540
Agreed, this echoes my experience with my Hypertherm (Powermax 65); SSR would not work. I had to use the mechanical relay (gun shy to say dry contact closure around these parts) the manual called for. So that makes at least 2 of us that SSR would not work for firing the torch reliably.
Personally I do not use any contact wetting resistors for my arc-ok. I have not found that to be necessary in my case/environment/power source. Maybe that will bite me in the arse later, if/when it does, I'll add a resistor
EZ PZ. For now, it is perfectly reliable.
I would be happy to do so. I will try to get that data sometime this week (weekend at the latest).
Replied by snowgoer540 on topic Powermax 45xp lost arc delay
Last edit: 14 Feb 2021 21:32 by snowgoer540.
14 Feb 2021 22:02 #198856
Note that a normal external SSR block type relay's would not be expected to work well
as these often need a minimum current and have significant voltage drop because they use
bipolar transistors and must get their base drive from the switched power side
A MOSFET type SSR would be superior to a mechanical relay
14 Feb 2021 22:03 #198857
This has gotten so much out of hand that i need to source a 7i96 as soon as possible to test this.
I would venture a guess that all the issues stem from the interference caused by the high voltage torch start.
The smallest SSR i have are 12A AC ones so not really useful for this.
- phillc54
14 Feb 2021 22:12 #198861
by phillc54
FWIW I use a 7i96 to directly switch the torch on my Powermax30 without any issues. Although that is obviously not a CNC ready machine.
- Nick7251
- Thank you received: 10
15 Feb 2021 06:28 #198902
by Nick7251
Where do you call home? Odds are really low you are near me, but if so you could use mine for some testing. I'm in Utah USA.
Replied by Nick7251 on topic Powermax 45xp lost arc delay
Time to create page: 0.201 seconds
