Plasma set up
- vk7dy
27 Feb 2021 11:50 #200282
by vk7dy
Plasma set up was created by vk7dy
To all, I have a cnc router running linux cnc. i want to run a plasma torch on it using L/cnc.
can i get some one to help me with the set up procedure.
regards Ken
Tasmania.
regards Ken
Tasmania.
- Clive S
- Thank you received: 486
27 Feb 2021 12:03 #200283
by Clive S
First I would read and study
forum.linuxcnc.org/plasmac/37234-plasmac-documentation
Replied by Clive S on topic Plasma set up
regards Ken
Tasmania.
- Thank you received: 7460
27 Feb 2021 17:40 #200317
There are plenty of us that can help, just do some reading to get a rough idea.
Replied by tommylight on topic Plasma set up
The land of the Tasmanian devil ???regards Ken
Tasmania.
- Thank you received: 4135
27 Feb 2021 21:12 #200344
Replied by rodw on topic Plasma set up
Well there are two options:
1. Create a new config for plasma. This would be pretty quick becasue you could give the plasmac configurator and feed it your existing config for it to add the plasm specific stuff.
2. Use Linuxcnc's multispindle feature (Plasmac uses it for engraving) so you can manage it all in one config where spindle 0 = plasma and spindle 1 = router. You might need to change the Plasmac defaults so it does not filter out Z axis code. You'd probably still follow method 1 to start with.
In fact I think if you did option 1 and set the spindle on relay to be the engraver, you'd be part way there. I would hand edit the config to use a different spindle number for the router to avoid all the engraver specific stuff.
- vk7dy
28 Feb 2021 12:27 #200395
by vk7dy
Replied by vk7dy on topic Plasma set up
thanks for the valued info
- vk7dy
28 Feb 2021 12:29 #200396
by vk7dy
thanks i will get started..
Ken
Ken
Time to create page: 0.120 seconds
