Working on new QtPlasmaC machine
  • Pro_El
  • Pro_El's Avatar Topic Author
  • Premium Member
  • Premium Member
11 Mar 2021 00:17 #201766 by Pro_El
Working on new QtPlasmaC machine was created by Pro_El
Hello all, i am starting to work on my new project, that is new plasma machine with 7i77, THCAD 300, LCNC 2.9 and QTPlasmac. I have made some research but i have some question.
1. Can i use ClassicLadder on QtPlasmaC, normally to configure ladder with my base-machine configuration
2. I found one PP for PlasmaC revision F and one PP for PlasmaC inside new version of SheetCam. They don't look the same. Which one to use?
3. I have plasma cutter TehnoSol that can receive signal from 0 to 10V analog for output Amps adjust. I now this is solved for HyperTherm via serial communication but i want to now is this possible to control with QtPlasmaC.
That is all for now, thanks to all good people
11 Mar 2021 05:31 #201777 by phillc54
Replied by phillc54 on topic Working on new QtPlasmaC machine
I can't see why not.
I am not sure which version is in SheetCam, so use the one from here
I don't know enough about the 7i77 but you can connect to either of the hal pins qtplasmac.cut_amps-s (S32) or qtplasmac.cut_amps-f (Float) to get the required cut amps.
The following user(s) said Thank You: Pro_El
Time to create page: 0.161 seconds
