QtPlasmaC release.
5 years 3 months ago #213725 by phillc54
Replied by phillc54 on topic QtPlasmaC release.
Spent half day trying to make two machines sleep, not once! :(
This was in Mode 1, will test mode 0 next.
Damn, in mode 0 it was doing it all the time yesterday!
That always seems to be the way Tom. :)
Suggestion:
Run from line works perfectly, but when stopping a run it reverts back to full gcode, how much trouble would it be to stop it from doing that and remaining in run from line till reload?
I "think" it wouldn't be too difficult, seems like a good idea, I will take a look.
5 years 3 months ago #213746 by phillc54
How is this Tommy?
The following user(s) said Thank You: tommylight, Clive S, Arpad, snowgoer540
5 years 3 months ago #213749 by tommylight
Replied by tommylight on topic QtPlasmaC release.
Sitting in the sun having a coffee so i can not see the screen properly, but it seems OK
And again: damn, that was fast! :)
5 years 3 months ago #213786 by tommylight
Oh well,
Several days back i went to check a machine that uses QTPlasmaC and found every setting back to default so as a normal person i thought the owner has deleted them by accident....
Today i start the big machine (updated yesterday, worked all day no issues at all) and low and behold everything is at default as noticed by 600V on the voltage display, but since i always have backups i just copy and paste the pref's file>
-start from the desktop shortcut=works OK,
-exit>start from shortcut=empty,
-copy again >right click on ini>open with LinuxCNC=works OK,
-exit>start from shortcut= works OK for several times
Note, all machines have a startup shortcut and it worked OK always, the desktop shortcut uses /usr/bin/linuxcnc while the startup shortcut uses linuxcnc only, although i doubt that changes anything, but i do close and open LinuxCNC quite often and had no problem with this till using the desktop shortcut on both machines.
5 years 3 months ago #213787 by tommylight
How is this Tommy?
Had another watch, that is exactly what is needed.
When stopping the machine it would also move the gremlin view to the start so everything else would go off screen and required a lot of scrolling on big plates then finding where it got stuck and moving on, gets very annoying very fast as the client has power issues so stops are normal there.
This should be perfect, thank you, as always you are magnificent ! :)
5 years 3 months ago #213789 by tommylight
You should do testing with this:
I do have more complicated stuff, just in case ... :)
Time to create page: 0.130 seconds
