THC not controlling
  • wade956
  • wade956's Avatar Topic Author
  • Junior Member
  • Junior Member
21 Mar 2021 17:04 #203135 by wade956
THC not controlling was created by wade956
Hi all, I have converted to QTPlasmac and since them it appears my THC is not moving. It does appear to call to move the z axis but it doesn't move. Any suggestions would be appreciated. Even with plasmac it was slow but it did move.
21 Mar 2021 17:53 #203140 by snowgoer540
Replied by snowgoer540 on topic THC not controlling
I was doing a little testing myself today, and I see the same issue.
I am confident Phill will get it sorted, just hang tight :)
The following user(s) said Thank You: wade956
22 Mar 2021 01:46 #203188 by phillc54
Replied by phillc54 on topic THC not controlling
Thanks for reporting this, I forgot to give THC a feed rate. :blush:
The fix has been pushed. If you have a Buildbot install then you will need to wait until the Buildbot is finished.
buildbot.linuxcnc.org/buildbot/grid
The following user(s) said Thank You: snowgoer540, wade956
Time to create page: 0.217 seconds
