Turn existing config into a simulator
- AgentWD40
- Thank you received: 96
13 Apr 2021 16:25 #205809
by AgentWD40
Turn existing config into a simulator was created by AgentWD40
Is there a simple way to turn an existing machines config into a simulator mode?
This is a pncconf->configurator.py generated config for a 7i96 plasmac machine. I'd like to be able to run sims without the 7i96 being plugged in.
- Thank you received: 2181
13 Apr 2021 20:32 #205824
Replied by cmorley on topic Turn existing config into a simulator
currently there is no option to easily turn a mesa base conffig into a simulator.
In master branch there has recently been work on adding qtplasmac to stepconf and it can produce a simulated config.
So you could produce a similar config in stepconf and use it as a simulator.
The following user(s) said Thank You: AgentWD40
Time to create page: 0.441 seconds
