Plasmac or QtPlasmac?
- txtrone
- Thank you received: 106
14 Apr 2021 23:15 #205947
by txtrone
Plasmac or QtPlasmac? was created by txtrone
I have my base machine setup, getting very near installing plasmac onto linuxcnc 2.8 Mint. This is will be my first time to install plasmac. Should I stop now and install Qtplasmac instead? If so, should I upgrade to 2.9??
- snowgoer540
- Thank you received: 907
14 Apr 2021 23:41 #205952
by snowgoer540
Replied by snowgoer540 on topic Plasmac or QtPlasmac?
In the end the choice is yours. However a few things to consider... PlasmaC (on Axis or Gmoccapy) is no longer supported.
QtPlasmaC only runs on 2.9.
Maybe I’m biased, but I think QtPlasmaC is great. There were also several critical bug fixes that are not pulled into PlasmaC.
Hope that helps, happy to answer any question you might have.
The following user(s) said Thank You: txtrone
- txtrone
15 Apr 2021 00:31 #205957
by txtrone
It seems to make sense then to go with Qt. Will I need to re-do my base machine config when I upgrade to 2.9?
Replied by txtrone on topic Plasmac or QtPlasmac?
- snowgoer540
15 Apr 2021 01:05 #205962
by snowgoer540
If you've never made a working plasmac config, yes. But the good news is thanks to Phill, pncconf now allows you to add all the plasma inputs up front. Should be pretty easy to duplicate. You may even be able to open your .pncconf file and just add to whats there with the new version.
- txtrone
15 Apr 2021 19:36 #206035
by txtrone
Cool. I will backup everything I have and upgrade to 2.9 tomorrow or Saturday. I am sure there is a tutorial on the upgrade somewhere.
