Does putting *.txt in the ini file work
23 Apr 2021 14:11 #206870 by Clive S
Using QTPlasmaC .
[FILTER]
PROGRAM_EXTENSION = .ngc,.nc,.tap GCode File (*.ngc, *.nc, *.tap, *.txt)
It displays the line in the GUI but it does not show the *.txt file in the folder
23 Apr 2021 14:27 #206872 by snowgoer540
Replied by snowgoer540 on topic Does putting *.txt in the ini file work
Using QTPlasmaC .
[FILTER]
It should, you're just half way there. :)
Try this:
PROGRAM_EXTENSION = .ngc,.nc,.tap,.txt GCode File (*.ngc, *.nc, *.tap, *.txt)
The following user(s) said Thank You: phillc54, Clive S
23 Apr 2021 14:45 #206873 by Clive S
Replied by Clive S on topic Does putting *.txt in the ini file work
Using QTPlasmaC .
[FILTER]
Try this:
Doing it the way I had it worked in PlasmaC and general other configs. So must be a QT thing B)
Thanks.
Time to create page: 0.520 seconds
