Is this a typo in the PNCCONF setup for Qtplasmac
- beefy
- Thank you received: 58
23 Apr 2021 22:22 - 23 Apr 2021 22:24 #206892
by beefy
See where it says: "Divider Ratio or Series Resistance"
Should it be: "Divider Ratio FOR Series Resistance"
I used 4 x 470 Kohm resistors in series with the THCAD-10 input.
Measured the total resistance of those when connected in series and got 1.886 Megohm.
This gives me a ratio of 19.86
However, PNCCONF does not accept this number, and resets itself to 20.
So I thought I could choose to enter the series resistance value directly and PNCCONF had been programmed to notice the very high figure and realise this is the resistance value and not the ratio. But now Qtplasmac is showing about 800v on screen when I start it up.
That made me think about the possible typo mentioned above.
Keith
Is this a typo in the PNCCONF setup for Qtplasmac was created by beefy
Keith
Last edit: 23 Apr 2021 22:24 by beefy.
- phillc54
- Thank you received: 2100
23 Apr 2021 23:40 #206901
by phillc54
Replied by phillc54 on topic Is this a typo in the PNCCONF setup for Qtplasmac
- beefy
24 Apr 2021 00:39 #206906
by beefy
Replied by beefy on topic Is this a typo in the PNCCONF setup for Qtplasmac
Ah I see, cheers Phill.
And very sorry for bothering you when I should have just looked in the PNCCONF help file. I'll try not to be so dumb next time.
Well, looks like I've got something else going on then. Initially I entered my series resistance value 1886000, but when starting Qtplasmac the arc volts display is fluttering around 800v.
Before I seen your reply I tried a value of 20 in the Divider Ratio box, yet when starting Qtplasmac again, the volts display is still hovering around the 800v mark.
I measured the output frequency of the THCAD and as expected got 121 Khz which matches the calibration sticker 0v value.
Keith
Keith
- phillc54
24 Apr 2021 00:44 #206908
by phillc54
Can you look for in qtplasmac.prefs in the [PLASMA_PARAMETERS] section there should be values for Arc Voltage Offset and Arc Voltage Scale = 1.0
An easy way of posting your config IF QtPlasmaC starts is on the PARAMETERS tab there is a BACKUP CONFIG button
- snowgoer540
- Thank you received: 907
24 Apr 2021 00:47 - 24 Apr 2021 00:56 #206909
by snowgoer540
Did you set the scale and offset?
linuxcnc.org/docs/devel/html/plasma/qtpl...c.html#qt_mesa-thcad
There’s a calculator there.
Also, I’d you click backup on the parameters tab, it makes a nice compressed file for posting here, and includes a couple extra files that help us help you.
Edit: whoops, that’s calculated by pncconf now.. carry on
Replied by snowgoer540 on topic Is this a typo in the PNCCONF setup for Qtplasmac
Last edit: 24 Apr 2021 00:56 by snowgoer540.
- snowgoer540
24 Apr 2021 00:49 #206910
by snowgoer540
Haha guess Phill beat me to it!
- phillc54
24 Apr 2021 00:55 #206911
by phillc54
Keith, it looks to me like this PnCconf config was saved to an existing directory. Try again with the same .pncconf file but rename the original directory first.
- beefy
24 Apr 2021 01:20 #206917
by beefy
Phill,
that PNCCONF file was off a USB drive, because I copied all the config files from the actual plasma table PC, so I could view them back on my Windows PC in the house, for learning about them.
OK I'll go and get the files you requested.
Keith
Phill,
Keith
- phillc54
24 Apr 2021 01:23 #206918
by phillc54
I was a bit unclear...
What I meant was to rename the existing ~/linuxcnc/configs/BEEFYS_PLASMA directory then run PnCconf and open BEEFYS_PLASMA.pncconf with it and run through to the end to create a new BEEFYS_PLASMA config.
- beefy
24 Apr 2021 01:50 #206921
by beefy
Time to create page: 0.511 seconds
