Is this a typo in the PNCCONF setup for Qtplasmac
24 Apr 2021 01:52 #206922 by beefy
I was a bit unclear...
What I meant was to rename the existing ~/linuxcnc/configs/BEEFYS_PLASMA directory then run PnCconf and open BEEFYS_PLASMA.pncconf with it and run through to the end to create a new BEEFYS_PLASMA config.
OK I think I got that. I'll go and see to it.
Keith
24 Apr 2021 01:55 #206923 by phillc54
Man, I should read :blush:
Sorry, for a 4x3 config it is in the SETTINGS tab
24 Apr 2021 02:11 #206924 by beefy
I think you cracked it Phill.
Now on screen:
Voltage Offset = 3793.750
Voltage Scale = 0.007728
And the arc voltage is displaying ZERO instead of 800.
Keith
24 Apr 2021 02:16 #206925 by beefy
Don't know if it's needed now but here's that backup file.
Keith
File Name: BEEFYS_PLA...2.tar.gz
File Size:10 KB
24 Apr 2021 02:17 #206926 by phillc54
That is great.
The current PnCconf won't overwrite qtplasmac.prefs so if it existed then the setting would not have been applied.
I have a verson in the wings that will read an existing .prefs and change those two parametrs. It will be a while before it is released though. I probably should add a note to the docs in the meantime.
24 Apr 2021 02:28 - 24 Apr 2021 02:29 #206927 by beefy
Done some more checks Phill.
Stuck a 9v battery directly on the THCAD 10v inputs and got 176 volts.
Then stuck the battery across the resistor bank and got 9v, so everything seems to be working perfect there.
What can I say, thank you so much for that help on a Saturday morning. I hope you have a great weekend.
Same goes for you Snowy.
Keith
Last edit: 24 Apr 2021 02:29 by beefy.
The following user(s) said Thank You: phillc54, snowgoer540
Time to create page: 0.335 seconds
