No torch relay output
27 Apr 2021 19:55 #207252 by chuben
No torch relay output was created by chuben
Hi I am new to Linuxcnc plasma and am having trouble activating the torch relay. This is my Hall and Ini setup in case you can see if there is something wrong. Thanks.
27 Apr 2021 20:03 #207255 by tommylight
Replied by tommylight on topic No torch relay output
Moved to QtPlasmaC.
Your hal file has no pins for anything required for QtPlasmaC, so give us all the info and start by reading the docs:
linuxcnc.org/docs/devel/html/plasma/qtplasmac.html
27 Apr 2021 21:51 #207271 by chuben
Replied by chuben on topic No torch relay output
Excuse me but I have followed the Pnconf configurator and it is what I got.
27 Apr 2021 22:05 #207273 by snowgoer540
Replied by snowgoer540 on topic No torch relay output
Read the docs it has a section on getting qtplasmac:
For starters, you need to be on 2.9.
27 Apr 2021 22:07 #207274 by chuben
I am using Linuxcnc 2.9
27 Apr 2021 22:10 #207275 by snowgoer540
The headers from your posted .ini and .hal files suggests otherwise...
# Generated by PNCconf at Tue Apr 27 15:00:33 2021
# Using LinuxCNC version:  2.8
# overwritten when you run PNCconf again
27 Apr 2021 22:20 #207277 by chuben
I already saw it. But I assure you that I am running 2.9. That could be happening?
27 Apr 2021 22:41 #207279 by tommylight
You did not enter any pins in Pncconf, it will need the torch on pin, float switch or ohmic pin, encoder or up/down pin, and/or arcok pin.
28 Apr 2021 09:31 #207295 by bevins
Replied by bevins on topic No torch relay output
Start halshow and bring up torch-on signal and see if it comes on in software. That will determine if it is hardware or software.
If the light is coming on and you get no relay then check your wiring and make sure your relay is on the correct pin.
torch-on is a fundamental core feature of a plasma machine. I highly doubt it is not working unless you have a misconfiguration or a wiring problem.
Are you enabling the torch in the gui? That you have to manually turn on or you get no torch.
28 Apr 2021 10:07 #207297 by snowgoer540
While you're looking at halshow, look at the main program window header, and note the version of linuxcnc.
Time to create page: 0.920 seconds
