Breakaway sensor config
  • txtrone
  • txtrone's Avatar Topic Author
  • Platinum Member
  • Platinum Member
29 Apr 2021 16:20 #207384 by txtrone
Breakaway sensor config was created by txtrone
When I remove the torch holder from gantry car the light on my PlasmaC panel lights up red, indicating the torch has come off... but it does not stop/pause the machine. I am running Plasmac on LinuxCNC 2.8.
  • thefabricator03
  • thefabricator03's Avatar
  • Visitor
  • Visitor
29 Apr 2021 20:51 #207396 by thefabricator03
Replied by thefabricator03 on topic Breakaway sensor config
I cant be of 100% help but I think you need to link your torch break away switch in your HAL file to the pin for the pause. I am sure Phill will be in soon and tell you exactly how to set that up..
  • Moderator
  • Moderator
29 Apr 2021 21:02 #207402 by tommylight
Replied by tommylight on topic Breakaway sensor config
I think Phill is out with that Jameson "guy" again ... :)
  • txtrone
  • Platinum Member
  • Platinum Member
29 Apr 2021 21:06 #207404 by txtrone
Replied by txtrone on topic Breakaway sensor config
I found something in the manual about adding halui.program-pause ... but there was no other info (that I found) which covered this topic. I tried adding this line 'net db_breakaway.in halui.program-pause' to the connections file under misc halui, but it errored out that halui,program-pause did not exist.... or something like that. I left that line in and commented it out for now.
  • txtrone
  • Platinum Member
  • Platinum Member
29 Apr 2021 21:08 #207406 by txtrone
heh. I used to hang out with Jameson, but he talks too much. Lately I have been hanging out with my amigo Don Julio. ;)
  • thefabricator03
  • Visitor
  • Visitor
29 Apr 2021 21:10 - 29 Apr 2021 21:11 #207407 by thefabricator03
halui,program-pause might not exist depending on how Phill has set up the version of PlasmaC you are using, have a look in the pins in hal show to see the exact pin names and try again.
I had that problem a while ago when setting up some pins and I had a . when I should of had a -
Last edit: 29 Apr 2021 21:11 by thefabricator03.
  • txtrone
  • Platinum Member
  • Platinum Member
29 Apr 2021 21:18 #207408 by txtrone
I hate it when that happens! When I do find the correct hal pin, it does go in the # ---HALUI signals--- section like this example, right?
net db_breakaway.in halui.thecorrect-pin
  • thefabricator03
  • Visitor
  • Visitor
29 Apr 2021 21:28 #207413 by thefabricator03
I would go to that section and set the pins you think are the correct ones and watch them as you pause the machine and see if they change state so you know they are the correct pins. Hal show makes finding the correct pins pretty easy if you use it correctly.
29 Apr 2021 22:54 #207418 by bevins
Replied by bevins on topic Breakaway sensor config
There is a breakaway input in plasmac. You need to connect that.
  • txtrone
  • Platinum Member
  • Platinum Member
30 Apr 2021 20:41 - 30 Apr 2021 20:44 #207486 by txtrone
You were right about syntax, there was an error in the line 'halui.program-pause' I corrected it to 'halui.program.pause' ,,, but then I get this error:
twopass: Error in file ././plasmac/plasmac.tcl:
    Pin 'halui.program.pause' was already linked to signal 'db_breakaway'
The contents of my hal file 'HALUI signals' section:
net axis-select-x  halui.axis.x.select
net jog-x-pos      halui.axis.x.plus
net jog-x-neg      halui.axis.x.minus
net jog-x-analog   halui.axis.x.analog
net x-is-homed     halui.joint.0.is-homed
net axis-select-y  halui.axis.y.select
net jog-y-pos      halui.axis.y.plus
net jog-y-neg      halui.axis.y.minus
net jog-y-analog   halui.axis.y.analog
net y-is-homed     halui.joint.1.is-homed
net axis-select-z  halui.axis.z.select
net jog-z-pos      halui.axis.z.plus
net jog-z-neg      halui.axis.z.minus
net jog-z-analog   halui.axis.z.analog
net z-is-homed     halui.joint.2.is-homed
net jog-selected-pos      halui.axis.selected.plus
net jog-selected-neg      halui.axis.selected.minus
# net spindle-manual-cw     halui.spindle.0.forward
# net spindle-manual-ccw    halui.spindle.0.reverse
# net spindle-manual-stop   halui.spindle.0.stop
# net machine-is-on         halui.machine.is-on
net jog-speed             halui.axis.jog-speed
net MDI-mode              halui.mode.is-mdi
#net db_breakaway          halui.program.pause
Here are some screenshots from hal show. I am just not understanding where the breakdown in communication is between hal and plasmac. The sensor is working, lights indicating on the plasmac axis gui, indicating in hal show, just will not stop the gantry.
Last edit: 30 Apr 2021 20:44 by txtrone.
Time to create page: 0.731 seconds
