Which THCAD to use for Plasma cutter without voltage divider
- Thank you received: 5337
13 Jun 2021 08:50 #211936
Replied by PCW on topic Which THCAD to use for Plasma cutter without voltage divider
The 7I96 can have up to 4 hardware MPG counters, but each MPG steals 2 pins from
the 7I96's 11 inputs
- AdrianS
31 Aug 2021 05:17 #219234
by AdrianS
Replied by AdrianS on topic Which THCAD to use for Plasma cutter without voltage divider
Stupid question, If someone had a THCAD 300 and later realised there Cutmatic 45 (WIAs version of the Razor Cut 45) was a pilot arc and was having trouble finding the inverter output, could the add a resistor to each leg of a near 1M value and use it as a THCAD 10?
- Thank you received: 7509
31 Aug 2021 06:34 #219238
Replied by tommylight on topic Which THCAD to use for Plasma cutter without voltage divider
