QTPlasmac and estop-latch broken (no iocontrol.0.user-request-enable)
  • rodw
  • Topic Author
  • Platinum Member
  • Platinum Member
5 years 3 months ago #215626 by rodw
This took a bit of sorting out but I eventually found the bug.
When you use estop latch, it requires a reset signal to take it out of estop.
According to the documents, and posts by Bevins and BigJohnT, this reset signal should be connected to
If you fire up an axis sim or even an early QTplasmac sim (pre estop modes) and monitor this signal in halscope, you will observe a pulse on this signal when the GUI estop is pressed. This is what resets the latch.
When I monitor this signal in QTPlasmac, there is no pulse so the latch is never reset.
Myself, Bevins and BigJohnT are some I know who use estop-latch. In my case I use it to create a chain for 3 estop buttons which has worked flawlessly until I tried to use QTplasamc.
Surely, it not prudent for a GUI to not fully support estop functionality.
Can this be fixed please?
I know it could be worked around with some hal logic, but really the features of estop latch are there for a reason so I don't really want to do something half arsed with estop.
5 years 3 months ago #215630 by phillc54
QtPlasmaC uses a stock QtVCP actionbutton for estop. The estop modes only affect how the button appears in the GUI and whether or not the button is enabled, not the function of the button.
In the sim it may have been hal connections that did the work. A look at the Axis code shows no reference to iocontrol.0.user-request-enable so it may well be hal connections there as well.
I just switched mine to estop mode 2 and when you press the estop button to go out of estop it pulses iocontrol.0.user-request-enable.
Warning: Spoiler!
  • rodw
  • Topic Author
  • Platinum Member
  • Platinum Member
5 years 3 months ago #215631 by rodw
Cool, I'll try a bit harder. I played at home last night to get to the bottom of this and to map out the estop-latch on an earlier version of QTplasmac so today I just set to mode 2 at work and looked in halscope and could not see the pulse.
5 years 3 months ago #215632 by phillc54
I couldn't see it in halshow but it is consistent in halscope, probably a bit quick for halshow.
  • rodw
  • Topic Author
  • Platinum Member
  • Platinum Member
5 years 3 months ago #215635 by rodw
There is something definitely wrong here. I cannot get it to work and I cannot see that pulse in QTplasmac.
I copied my whole estop from gmoccappy to QTplasmac and it just does not work period!
Could htere be a dependency missing? My load history is shown below
Just don't delete plasmac for a while!
edit, no its not. the forum said there were too many URLS
  • rodw
  • Topic Author
  • Platinum Member
  • Platinum Member
5 years 3 months ago #215636 by rodw
part 1
hm2/hm2_7i76e.0: registered emc:task:emctask.cc 69: interp_error: File not open File not open emc:task:emctaskmain.cc 3080: can't initialize interpreter qt5ct: using qt5ct plugin [QTvcp.QTVCP.QT_PSTAT][INFO]  Using DEFAULT handler file path: [QTvcp.QTVCP.QT_PSTAT][INFO]  Using DEFAULT ui file from qtplasmac.ui (qt_pstat.py:116) [QTvcp.QTVCP.QT_PSTAT][INFO]  No qss file found (qt_pstat.py:152) [QTvcp.QTVCP.QT_PSTAT][INFO]  No qrc file found (qt_pstat.py:176) [QTvcp.QTVCP.QT_PSTAT][INFO]  No resources.py file found, No QRC file to compile one from. (qt_pstat.py:197) [QTvcp][INFO]  Building A Linuxcnc Main Screen with Python 2 (qtvcp:136) [QTvcp][INFO]  No handler file specified on command line (qtvcp:154) [QTvcp][INFO]  No HAL component base name specified on command line using: qtplasmac (qtvcp:185) [QTvcp.QTVCP.WIDGETS.CAMVIEW_WIDGET][ERROR]  Qtvcp Error with camview - is python3-opencv installed? (camview_widget.py:47) [QTvcp.QTVCP.QT_MAKEGUI][INFO]  No resource file to load: None (qt_makegui.py:186) <commandline>:0: Pin 'ini.z.max_limit' does not exist <commandline>:0: Pin 'ini.z.min_limit' does not exist [QTvcp][INFO]  postgui filename: ['custom_postgui.hal'] (qtvcp:361)
  • rodw
  • Topic Author
  • Platinum Member
  • Platinum Member
5 years 3 months ago #215637 by rodw
[QTvcp.QTVCP.QT_PSTAT][INFO]  No qss file found (qt_pstat.py:152) [QTvcp.QTVCP.QT_PSTAT][INFO]  No qrc file found (qt_pstat.py:176) [QTvcp.QTVCP.QT_PSTAT][INFO]  No resources.py file found, No QRC file to compile one from. (qt_pstat.py:197) [QTvcp][INFO]  Building A Linuxcnc Main Screen with Python 2 (qtvcp:136) [QTvcp][INFO]  No handler file specified on command line (qtvcp:154) [QTvcp][INFO]  No HAL component base name specified on command line using: qtplasmac (qtvcp:185) [QTvcp.QTVCP.WIDGETS.CAMVIEW_WIDGET][ERROR]  Qtvcp Error with camview - is python3-opencv installed? (camview_widget.py:47) [QTvcp.QTVCP.QT_MAKEGUI][INFO]  No resource file to load: None (qt_makegui.py:186) <commandline>:0: Pin 'ini.z.max_limit' does not exist <commandline>:0: Pin 'ini.z.min_limit' does not exist [QTvcp][INFO]  postgui filename: ['custom_postgui.hal'] (qtvcp:361) [QTvcp][INFO]  Preference path:
  • rodw
  • Topic Author
  • Platinum Member
  • Platinum Member
5 years 3 months ago #215638 by rodw
This might be easier
File Name: error.txt
File Size:1.7 KB
5 years 3 months ago #215639 by phillc54
Does the qtplasmac link in your config directory point to a valid directory?
The following user(s) said Thank You: fernandosf
  • rodw
  • Topic Author
  • Platinum Member
  • Platinum Member
5 years 3 months ago #215644 by rodw
That should be a sub folder in the config folder shouldn't it?
