QTPlasmc GUI questions
01 Aug 2021 08:20 #216600 by robertspark
QTPlasmc GUI questions was created by robertspark
I was wondering if it was possible to change / expose (via the gui >> Parameters >> GUI Settings frame) the options to change the jog speed % (hare / tortoise) [same as gmoccapy] / or via hal/ini file?
I was also wondering if it was possible to change or expose the number of decimal places for the DRO's
None of these are show stoppers / issues of any significance, I was mearly just wondering if the settings could be changes as I can see + adjust them in gmoccapy thats all
01 Aug 2021 15:58 #216647 by robertspark
Replied by robertspark on topic QTPlasmc GUI questions
I was wondering if it was possible to lower the CUT AMPS within the material settings to 10A minimum (presently 15A), but the hypertherm 45xp uses 10A for marking,
thanks
01 Aug 2021 19:58 #216658 by phillc54
Replied by phillc54 on topic QTPlasmc GUI questions
We can take a look at all of those...
01 Aug 2021 21:27 #216664 by cmorley
Replied by cmorley on topic QTPlasmc GUI questions
DRO uses properties for the metric/imperial/angular templates
So you can change them with the stylesheet.
Maybe that's not convenient enough - you can always set properties directly in python code too.
The following user(s) said Thank You: robertspark
02 Aug 2021 02:56 #216672 by phillc54
There is a new hal pin for slow jogging, called qtplasmac.ext_jog_slow.
Cut Amps minimum is now 10.
I am not sure of the required styleshhet properties for the DRO, maybe Chris will post them here then you could set up a custom style or a custom stylesheet.
linuxcnc.org/docs/devel/html/plasma/qtpl...mizing_qtplasmac_gui
02 Aug 2021 07:58 #216691 by robertspark
thanks Gents
I'll have a play tonight
02 Aug 2021 08:06 - 02 Aug 2021 08:09 #216694 by cmorley
DROLabel{
qproperty-imperial_template: '%2.1f';
qproperty-metric_template: '%2.1f';
Then you will probably have to change cycle g20/g21 to get it to change.
I'll fix that bug soon.
Chris
Last edit: 02 Aug 2021 08:09 by cmorley.
The following user(s) said Thank You: phillc54, snowgoer540
Time to create page: 0.131 seconds
