ohm sensor
04 Aug 2021 06:28 #216899 by chuben
ohm sensor was created by chuben
Hi, I am new to linuxcnc and I have made a plasma cutting table and everything works fine but I am not able to install the ohm probe. For the ohmic probe I am using a thcad-5 and as a main card I am using a 7i76e table. Can someone help me with a tutorial?
04 Aug 2021 07:22 #216904 by snowgoer540
Replied by snowgoer540 on topic ohm sensor
Not the answer to your main question, but just by looking at the name of your backup files, I would recommend that you update, you are on v1.0.25 and the latest is v1.0.60 A lot has changed/improved, etc.
In case you'd like to look at the changes: htmlpreview.github.io/?https://github.co...lasmac/versions.html
05 Aug 2021 09:49 #216983 by chuben
Replied by chuben on topic ohm sensor
Thanks but I have updated and I am not able to install the ohmic sensor
The following user(s) said Thank You: paulsao
Time to create page: 0.126 seconds
